battery toast or other problem?
Old Jul 16, 2012 | 08:57 AM
roblaza's Avatar
So I jumped in the RA Saturday and noticed that when turning over, it was a little slower than normal, but it started up. Sunday rolls around and I get in and she turns over very slowly and wont start, then just clicks... AWESOME, battery is toast I think to my self. Hooked up the cables and boosted it and she fired right up. I took it for a spin and it ran fine, light not dimming at all, voltmeter reading at a hair under 14V the whole time. Came home and parked it for the night.
When I went out this morning, volts reading 11 on the gauge... turn the key and it turns over a few times then back to the clicking.
I'm calling a fried battery, but wanted more input as the little window on the battery itself still says okay. Opinions??
Old Jul 16, 2012 | 09:14 AM
rrstlevo's Avatar
yep, sounds like a bad battery. how old is the battery?
Old Jul 16, 2012 | 09:17 AM
roblaza's Avatar
Who knows. It's been in the car since I bought it 3.5 years ago, so it's probably about that time to be changed.
Old Jul 16, 2012 | 09:21 AM
slc-ralliart's Avatar
My guess would be battery. Do the auto parts stores in Canada do free electronic testing. Here in the states they will run a full diagnostic for free to determine if it is the battery, alternator, or something else.
I think I will be right behind you on battery replacement. I am still on the factory battery. 8 years old now.
Old Jul 16, 2012 | 09:24 AM
CrAnSwIcK's Avatar
battery is toast, or you have abnormal current draw when the car is off...
Old Jul 16, 2012 | 09:25 AM
roblaza's Avatar
I am 99.9% sure it's not the alternator, as when it is running none of the lights dim, and the volts are right where they should be. If the alternator was toast the car would die out shortly after starting up. The battery is just there to basically get the car started, after its running the alternator takes over.
Old Jul 16, 2012 | 09:26 AM
roblaza's Avatar
I just did the radio relocate, so maybe there's a pinched wire back in there somewhere... i'm going out right now to have a second look at it and make sure nothing is out of the ordinary
Old Jul 16, 2012 | 09:37 AM
roblaza's Avatar
It's the battery 100%. All the wires are free and clear from being pinched, and the little window on the battery went from being OK, to NOT OK. lol New battery is on route.
Old Jul 16, 2012 | 11:28 AM
roblaza's Avatar
Put the new battery in...fired right up. started out at almost 14V. now it's sitting at just over 13V. which could mean my alternator isnt keeping up with the demand. not cool man, not cool.
Old Jul 16, 2012 | 01:45 PM
RacerX-Ralliart's Avatar
Or it could mean your old battery wasn't taking a charge so the alt was putting out more voltage to try and charge the battery and now with the new battery it doesn't need to once you rev the engine up voltage will go up... Or something's loose like post connection
JesseOZ
Lancer Tranny/Drivetrain Tech
20
Jun 3, 2014 04:10 PM
Thahomeboyb
Lancer Troubleshooting
Jan 24, 2014 07:58 PM
Randal
17
Nov 24, 2012 03:46 PM
wazzelby
Sep 9, 2012 07:47 PM
ant_turbo
18
Jul 4, 2012 09:01 AM
