P2138 every couple of days
Old Apr 1, 2014 | 04:45 PM
mikemike396's Avatar
So I have been getting a cel every couple of days usually within the first 5 minites of starting the car. The car goes into limp mode and I have to turn it off to get it out of limp mode. I have been reading there is a flash at mitsubish that is suppose to fix this? Does anyone know anything about this?
Also I just replaced the apps sensor (behind the passanger light) and it came on today again. I thought for sure a new apps sensor would fix this. This is the link I was reading
http://www.justanswer.com/mitsubishi/4e3yg-lancer-mitsubishi-lost-power-km-me-rev-beyond-2500-3000-rpm.html
Old Oct 14, 2014 | 12:50 PM
Going back to the stock ECU fixed this issue. Haven't had the light come one yet since dumping hackish's flash.
Old Oct 14, 2014 | 08:30 PM
CrAnSwIcK's Avatar
hackish's flash doesn't have anything to do with the APPS...the problem may be with the ECU itself...have you tried reflashing with the latest definitions?
Old Oct 15, 2014 | 05:11 AM
I have not. Need a bench or a better way to upload the new definition. I could swap out the ECU and give it a try but the stock ECU has been running so well.
Old Oct 15, 2014 | 08:01 AM
CrAnSwIcK's Avatar
for the 04 models, once you have the initial flash you should be able to use a laptop + tactrix, like everyone else...
Old Oct 15, 2014 | 08:27 AM
I was never able to get the flash on my stock ECU due to the fact that the 04 didn't expose the vin number to hackish like the other 05,06 ECU's. So he didn't want to flash it because the point is to lock your vin onto your account so you cant go around flashing everyones ECU with one account. He sold me an 05 ECU that we were able to reflash and it worked for 8 months then started throwing that code. Put stock ECU back in and has been fine.
Old Oct 15, 2014 | 10:19 AM
OttRalliart05's Avatar
That was the scare but try flashing a 2004 ROM with a different ROMID you will get codes, many codes! Also you cannot flash a 04 rom on a 05 ECU and expect it to function properly. He was so determined for someone not to steal the work he either left out or was not aware there is no way to protect the work. MMCFLASH will read his protected files so bit of a waste of time really. I understand and fully agree there are many scumbags looking to steal technology but I am still a firm believer that most that pay for something don't give it away for free. Yepp there are dirtbags but I believe the majority are honest guys and appreciate/respect the work that has gone into this.
mikemike you may want to try his newer work, you were one of the first and back then there was alot of guess work and not much testing, case in point look at how your car is reacting. I know your situation and knowing what i know now your car should have never been attempted in this way. Since then I will admit his work is a lot better. He should fix this up for free it has been along time
LeftysRule22
May 22, 2021 05:08 AM
MadBoost23
Lancer Engine Management / Tuning Forums
Jun 10, 2015 11:57 PM
Chabada15
38
Oct 25, 2014 12:18 PM
mikemike396
Oct 29, 2013 09:58 AM
gizmotoy
Apr 28, 2009 12:46 PM
