Is My Ra )$ Lemon Law????????
Originally Posted by KevinD
i am kind of new to these cars as well but i may have a few things for you to check. first off your profile says you have a ralliart car? isn't the ralliart car different from the RS? i was under the impression the RS is the evolution and the ralliart was a regular lancer with a body kit. next, as for rotating the tires, on my EVO 8 you really can't rotate the tires because they are uni-directional (without removing them from the wheel and remounting them correct?) (front to back is the only acceptable rotation, which is ok with the wheel sizes being the same F/B). next any car with wider tires such as the EVO's track really bad. what i mean by this is: the roads in michigan have really deep "wells" where the common path for tires are. so when i had my porsche on the highway, the car would pull really hard left when i was in a well, but if i drove a little to the side of the well, it would track straight. this was very road specific and it only happened on ONE highway. you keep saying your car pulls left in the left lane, but not in the right lane. try driving your car at 70 on a different highway, does the same thing still happen?
Originally Posted by Deltarider99
Ok, first off, he's originally from Argentina and English is a second language to him. Second off, give him a damn break and learn all the facts before you start making judgments.
Thank You CICLON
This was post yesturday on THE UPDATES TOPICS.
THE CAR is FIX, The dealer had to do a little change to get the car to go strait, this is what they did this last time, Set the car up in the frame machine, resolt the car is Square, they prosided by installing new smaller Bolts in the front Strut to make later Camber Adjustments by doing this the cars stoped pulling to the Left, For does ho are having this same problem wich I know ther is more then one , here are the Parts # that have to be change, QTY 4 FP Number MR333560 Discr. Bolt.FR SUSP STRUT , To ho ever made need the SEPCS for allingment that they use at the dealer to fix this problem , e-mail me and I will send you a copy .
https://www.evolutionm.net/forums/sh...5&page=2&pp=15
Abacus
Sep 18, 2025 05:44 AM
