Ralliart Upgrades
Old Nov 7, 2008 | 10:22 AM
  #106
ambystom01's Avatar
Originally Posted by heavyD
What's your point? The turbocharger from the EVO will fit we just don't know if the manifold and downpipes will have to be changed. There's a good chance that they may be both the same making the swap a simple matter and even if you have to change the downpipe it's not like it complicates matters.
People will undoubtedly be making the swap but if you need other parts to make it work, it's not as simple as it would seem.
Other things to consider, how is the Ralliart fuel system setup?
Old Nov 7, 2008 | 12:08 PM
  #107
heavyD's Avatar
I'm willing to bet the fuel system is the same since the Ralliart is getting the same poor gas mileage as the EVO and at has a boost peak of almost 20 psi which is pretty close to the EVO's peak boost. I look at it this way. The engines are the same so swapping parts should be relatively simple. I swapped a few turbos back and forth between 1G 6-bolt DSM's and 2G 7-bolt DSM's and those cars had many more differences than the EVO X and Ralliart.
Old Nov 7, 2008 | 12:43 PM
  #108
EsRt2evo's Avatar
If you have to upgrade other parts to make it work, it's not a bolt-on part in the truest sense of the term.
I've heard that catback exhausts are interchangeable but I'm not sure about the full exhaust, downpipe and all. If Mitsubishi felt like being dinks, they'd make the two different thus forcing you to do further mods.
Ok so then it's two bolt ons?
No internal work is needed, and it's a direct swap. It's a bolt-on.
And if the Ralliart has a different turbo i would assume the Evo X's aftermarket downpipes are a no go.
Old Nov 7, 2008 | 01:07 PM
  #109
ambystom01's Avatar
Doesn't mean the fuel system is the same, it just means that both have crappy tunes. 20 PSI on a small turbo is also substantially different from 20 PSI on a big turbo.
Old Nov 7, 2008 | 01:09 PM
  #110
ambystom01's Avatar
Originally Posted by EsRt2evo
[B]
You'll need to replace the turbo, the intercooler, the intercooler piping, if the downpipes are different the exhaust system and if the fuel system is different the fuel system. It's the same on the WRX, I can just bolt the STI turbo in but to get it to work the way it's meant to, I need a TBE, the intercooler and the splitter.
Old Nov 7, 2008 | 01:31 PM
  #111
EsRt2evo's Avatar
I understand that. I'm just saying that stuff is bolt-on.
Old Nov 7, 2008 | 01:48 PM
  #112
chino ali's Avatar
I mean I am a little taken back that the fact that the turbo is hittin 20psi and that might be the reason why the fuel is not that great.
I was thinking along the lines or 12-15-psi.
Doesn't sometime turbos actually help you get better fuel management?
If it's spiking correctly with the way the car is set up?
Old Nov 7, 2008 | 01:57 PM
  #113
ambystom01's Avatar
Turbos were originally designed to increase fuel efficiency. The spike could be because of a delay between the closed loop and open loop maps.
Old Nov 7, 2008 | 02:08 PM
  #114
heavyD's Avatar
Well since the EVO X and Ralliart both use small turbos what's your point? The only difference between the turbos is that one is more efficient and will maintain flow at higher RPM's.
Old Nov 7, 2008 | 02:18 PM
  #115
ambystom01's Avatar
The Evo X uses a significantly larger turbo than the Ralliart. The Ralliart likely uses a similar turbo the older WRX which is smaller than the VF39/43 which is itself dwarfed by the 16G in the Evo.
Old Nov 7, 2008 | 02:50 PM
  #116
Robevo RS's Avatar
well another well informed racer
Many car would blow engine with that small X turbo
Just for understanding what i'm saying , it is an O2 housing comparison with the IX turbo set up :
probably you can insert the RA O2 housing inside the X O2 housing.
Old Nov 7, 2008 | 03:02 PM
  #117
Robevo RS's Avatar
as i heard even the IC set up swap is difficult. Also if you swap it why not upgraded it?
Why buy factory?
maybe the fuel system is a same but how the RA SST will react the bigger turbo? i'm sure it have a bigger lag. So even when you shift it might will fall under the desired RPM range for the new turbo set up.ETC.
Old Nov 7, 2008 | 06:50 PM
  #118
heavyD's Avatar
They made the O2 sensor housing larger and with a more tubular design but the actual turbocharger itself is still based on the 16G which isn't a large turbo. The size of cast housings has nothing to do with the size of the turbocharger. Really No use speculating on how small the Ralliart turbocharger and exhaust is until we see it out.
Old Nov 7, 2008 | 07:01 PM
  #119
ambystom01's Avatar
The Evo turbo is based on the 16G but it's a pretty big 16G. It's not a small turbo, it's best classified as a medium turbo.
Old Nov 8, 2008 | 05:50 AM
  #120
Robevo RS's Avatar
and it is much bigger then a RA. no speculation there , just from you only. It is a fact.
Not just a size is important. More important how much air can pass through it.
And there is where the X turbo design shines
It is a "same" size as a IX but flows much better./as the Mitsubishi tecnician guide stated/
And the tuned numbers
