Rearview camera for Sportback
Old Jan 7, 2012 | 08:37 AM
Texas325's Avatar
Thumbs up
Originally Posted by hccyong
Great, thanks for the info. I'd be interested to hear how the install goes for you. I'm curious as to what the recommended wire routing is and if the harness length is perfect for our car too, or if there's extra length that'd need to be coiled up somewhere.
Install went great! The harness itself is for both the Lancer and Outlander. I went through the left side of car. Followed the wire instructions for the Lancer Sedan to go from the Navi to the left door floor panel up to the tailgate including wrapping the extra slack.
The tailgate portion is different since the instructions were meant for the trunk so I followed the existing wires that leads to the tailgate.
The hardest part is going to the tailgate with the rubber tube. From there I lead it to the license plate lights.. There's about a foot of slack left since I was worried about not having enough when I install the camera (which won't be in until next week).
Everything works, the MMCS recognizes the camera harness when I go into reverse. Guidelines and safety warning pops up except it doesn't show video because the camera hasn't been install
Here are the instructions I followed but unplug the neg (--) cable from your battery as you are going to deal with the rear passenger side airbags when routing to the tailgate.
https://www.evolutionm.net/forums/ev...nse-plate.html
Old Jan 7, 2012 | 08:44 AM
Texas325's Avatar
Exclamation
Forgot to mention MZ380461EX is the Outlander's camera used for the tailgates....
DO NOT USE MZ380462EX - it's design to be flush to the sedan trunk and not angle for the tailgate.
I will confirm the Outlander's camera next week after the installation.
MMNA confirmed MZ380461EX goes into the 2012 Lancer and for the ones overseas but I'll be the guinea pig for the sportback owners =)
Old Jan 11, 2012 | 11:53 PM
hccyong's Avatar
Thanks for the followup, Texas325. Were you able to find a good deal on the Outlander camera? From a quick search, it looks like MitsubishiPartsPeople in WA has the best deal at $217. Thanks!
Last edited by hccyong; Jan 11, 2012 at 11:55 PM. Reason: Removed question that was already answered!
Old Jan 31, 2012 | 09:35 PM
hccyong's Avatar
Hi Texas325, Were you successful at installing the camera? Thanks.
Old Feb 13, 2012 | 03:50 AM
Texas325's Avatar
Sorry been busy this past month to post a full system install. Got the camera installed and it works perfectly. However there's a little modification of where should be installed. If I had to do it over again - take it to professional. Overall it does what it should - covers the area below the rear window.
Old Feb 13, 2012 | 11:29 AM
neogeo64's Avatar
Nice.. Makes me wish I got the Factory Nav.
Old Feb 16, 2012 | 09:41 PM
hccyong's Avatar
Texas325, thanks for the pics. I just got the parts today. I guess because the camera p/n was for the Outlander, those are the instructions I got. Did you get Sportback (or at least Lancer) instructions? The Outlander instructions ask to route along the passenger side of the car, which I think is opposite of Lancer. What's the modification on the installation location, and what was the toughest part?
Old Mar 4, 2012 | 12:06 PM
hccyong's Avatar
Texas325, how did you get into the rear view marker setting mode?
I got mine done about a week ago. The grommet going into the tailgate wasn't too bad for me after I applied some wax to the harness, and I was pleasantly surprised how none of the clips broke. I never quite figured out the correct order of removing the C pillar trim with respect to the side of the trunk trim, but I was able to get enough access to route through.
My main problem was the drilling of the sheetmetal. I think I see what you mean now. The template isn't quite lined up for our hatch. There's only a small zone where the camera would fit through the license plate garnish properly yet avoid the license plate lamp and the stud for mounting the garnish. I was off by a bit which meant I had to dremmel down the garnish plate a bit and also trim away a bit of the license plate lamp plastic. I'm not quite happy with how the "jack nut" gets exposed a bit when looking from the underneath, and I also lost quite a bit of time due to dropped parts in between the sheetmetal stampings. I'm curious as to whether Mitsubishi will come up with a Sportback specific part with an adjusted drilling template.
Old Mar 12, 2012 | 07:18 PM
Texas325's Avatar
The rear view marker mode is in the camera settings, there's two button you have to press to access (I think Set and Navi). Yea installing it was hard. I shouldve dremal part of the trim to save the hassle on making it fit perfectly on the sheet metal.
Old May 27, 2013 | 03:05 PM
Janko Ralliart's Avatar
Question re rear view camera
Hi Texas325
I can not see any of attachments you posted, wondering can you please send me images to jankovracar@shaw.ca, I have 2009 Mitsubishi Lancer Sportback Ralliart with OEM navi system and would like to install rear view camera, can you confirm what part numbers you installed, thanks
Old Jun 6, 2013 | 08:05 PM
dukeds's Avatar
removed. post by accident
Adam Arthursson
Lancer How Tos / Installations
Apr 15, 2016 01:34 PM
marcouxa1
51
Jan 10, 2016 06:47 PM
johnnnyjeans
11
Feb 20, 2014 06:20 PM
kpt6
Dec 23, 2013 03:34 PM
FaLeX
Future Lancer / Evo Models
160
Apr 7, 2009 11:05 PM
