OEM projector drl flicker HELP - Merged
#31
I am going to try out this hack. I have a HID kit & Jrox harness from before that I can reuse. I guess all I need are the D2S connectors instead of the 9006 connectors.
Btw 03chi-town0Z, When we had last spoke, I wanted to turn my Fogs into DRLs. I believe I found a way. I found a DRL module on amazon that I can use. All I would need to do is to order alternate H11 plugs that I can use to wire the Fogs instead of the factory harness. Anyways, I'll let you know how it all falls through in a couple of weeks.
#32
From what I've read on the forums, it appears 2010 RAs experience no problems with Evo X projectors. Can that also be said of 2011 RA? For the 2011
model, do I need to buy the DRL bypass harness and the special DS2 bulbs if it already had an aftermarket 9006 HID kit? Any ideas/suggestions would be greatly appreciated. Thanks in advance.
vizi0n
10
Oct 6, 2017 04:08 PM
mitsumaster
Nov 14, 2015 07:55 AM
