**A/C not blowing inside the Car**
Old Jul 17, 2011 | 09:00 AM
  #61
03chi-town0Z's Avatar
Ok, good. Now you're going to have to start checking at the ETACS. It's the white module, under the dash on the driver's side, right where the fuse block is. Here's a diagram of the connector identification:
Attached Thumbnails **A/C not blowing inside the Car**-etacs.gif
Old Jul 17, 2011 | 09:05 AM
  #62
First you will want to check on the volts setting at connector C-315. You'll put one of the meter's leads to a good ground, the other lead you're going to be touching to pin # 16 which is the yellow wire that sends power to the blower motor.
You're going to want to leave everything plugged in and just use a t-pin or paperclip or something to back-probe the connector, basically just something that can slip inside the slot with the wire and reach into the connector to make contact with the metal pin sleeve. Let me know what you get.
Old Jul 17, 2011 | 09:20 AM
  #63
08Lancer89's Avatar
Okay I will get back to you shortly with readings. Thanks
Old Jul 17, 2011 | 09:35 AM
  #64
08Lancer89's Avatar
Not really getting any power from there. Started at 0 then went max to .003 volts had a skips at 1 volt but that lasted a sec then fans kicked off no matter what setting I put them on could not get the fans to kick back on.
Old Jul 17, 2011 | 09:46 AM
  #65
08Lancer89's Avatar
Found the problem. Thanks to our diagram I found out what relay was to the blower motor since it's not labeled in the owners manual or anything. It was bad I swapped it with one that I knew was good and Wala it worked. Thank you so much for your help. If you were closer I'd buy you a beer.
Old Jul 17, 2011 | 01:44 PM
  #66
Slee256's Avatar
I'm sure he'd take a Paypal donation...
Old Jul 17, 2011 | 10:04 PM
  #67
There ya go. You didn't give me a chance to answer you after the last post, though.
When you said you had no voltage at pin 16, my next step was: ok, now remove the relay labeled # 303 on the ETACS and swap in a known good one and see what happens...But you already beat me to it... lol.
Just glad I was able to help ya out, even if it was only indirectly by sourcing pics
Old Jul 17, 2011 | 10:36 PM
  #68
JDMCT9MR's Avatar
Glad you got it fixed!
Old Jul 18, 2011 | 04:10 AM
  #69
I just can't believe this little diag thread has over 700 views, lol
Old Jul 18, 2011 | 09:17 AM
  #70
08Lancer89's Avatar
Thank you so much man the pics were very helpful
Old Jul 18, 2011 | 12:23 PM
  #71
total0wnage's Avatar
i think thats cause ppl like me who dont really know about all this stuff are reading through cause their bored lol Glad you got it fixed tho
AzNvPo4sHo
May 2, 2021 07:46 PM
xX Cangri Xx
Aug 21, 2015 08:12 AM
kd5byb
Lancer Troubleshooting
Sep 7, 2013 05:44 AM
nile13
Jul 31, 2013 12:14 PM
dudical26
52
May 4, 2011 06:42 AM
