Battery options
Old Jan 23, 2012 | 07:56 PM
BravoZero's Avatar
Battery options
I'm looking into doing a little bit of audio work in my '11 RA, and got a Kicker 700.5 five-channel amp for Christmas. I'm not going to run a full 1,000+ watt system like I did in my Eclipse because I still want to do a lot of performance work on this car, which in the end might be hard to balance out. I'm thinking about relocating the battery to the trunk along with a single 10" sealed sub, and running front component speakers and rear 2 way speakers in the cabin, probably keeping the stock head unit since I have iPod capabilities already and I don't need navigation.
With audio comes upgrading the battery, and in my Eclipse I got away with using an Optima Redtop running four 80w speakers with the fronts being components, and had an Alpine Type-R 12" running at 800-900 watts. Only when it reached maximum power did I notice the lights starting to dim, never used a capacitor.
So, if I want to run a setup with about 400w combined on all five channels, and want to get the most performance out of the car, any suggestions for a battery? I'm thinking of just going with another Redtop battery, and maybe looking into enhancing the engine grounding, like the "big 3" upgrade. Also, any opinions on battery relocating?
Old Jan 24, 2012 | 08:36 AM
crak's Avatar
I am no pro, but from an electrical standpoint all batteries are 12V. If you want to make a difference you would want to get a wire with a lower gauge. That might help for your setup if you are pulling more power.
If it still is under 1000 watts I think standard wires are fine with a standard battery. MY 2 cents. I am only 80% sure, hopefully someone with more experience can help.
Battery relocating to the trunk is always an option like the EVO's
Old Jan 24, 2012 | 09:03 AM
Brownie614's Avatar
in my 2011 ra i got 2 12in Memphis audio subs with a 1000watt kenwood amp n my battery is fine my volt gauge dont drop hardly at all im gonna put more power into my car im turning it into a show car
Old Jan 24, 2012 | 12:21 PM
Veronica's Avatar
But combined with the losses from moving the battery to the trunk - you may need to upgrade the alternator too.
Old Jan 24, 2012 | 12:30 PM
BravoZero's Avatar
That depends... if it's the same alternator that the X has, then I should be fine. I've seen an MR with an 800w audio system and he only upgraded the battery, has the stock alternator and no capacitor. Hasn't had an issue.
ddlopresti
Feb 23, 2015 01:17 PM
tjac357
11
Jul 28, 2012 06:58 PM
stert
18
Feb 26, 2010 08:51 AM
lancerguy0208
53
Jan 6, 2010 11:26 AM
BalistiK_EvoIX
12
Jan 13, 2009 06:49 PM
