Gas Overflow
Old Jan 21, 2013 | 05:52 AM
packman86's Avatar
Gas Overflow
I just got a 2010 Ralliart and I have noticed that the gas pump does not stop automatically when the tank is full. This has happened to me twice now.
Conditions outside might be a factor for the actual pump, as it is well below freezing where I live right now.
Or is there something with the car that does not trigger the pump to stop?
Old Jan 21, 2013 | 05:57 AM
Wahtash's Avatar
If the pump stopped before the tank was full and/or had to be restarted many times to fill the tank, that would indicate a problem on the car side. Not stopping when full is a problem on the gas pump side.
Old Jan 21, 2013 | 06:03 AM
skills's Avatar
What would the problem on the car side be? This happened me once or twice, though since it was once or twice out of thousands of refuelings I figured it was benign and/or a pump issue.
Old Jan 21, 2013 | 08:09 AM
danike's Avatar
On a related subject, please help me. I live in Indiana and on snowy/rainy days where the temperatures are close to freezing, my gas lid will freeze shut. Then, to open it, its almost impossible even after breaking all the ice build-up. The hinge just doesn't seem to want to pop open. Any recommendations?
Old Jan 21, 2013 | 09:49 AM
mirage4g64's Avatar
warm up the gas door first
Old Jan 21, 2013 | 10:38 AM
Jay10Ralliart's Avatar
FCOTM Winner
I live in Indiana too and have never once had a problem with gas overflow and as far as the gas door when I didnt have a garage to store it I did have to use my keys a couple times to break the ice around the edge but since having it garaged now I no longer have those problems.
Old Jan 21, 2013 | 02:10 PM
stfuad's Avatar
If it's car side it's usually EVAP related e.g. EVAP vent not working correctly.
Lube the hinge/release every time you do your oil change.
Old Jan 21, 2013 | 02:11 PM
gaabbee's Avatar
Put a wedge to hold open the door release, phone or wallet works good then take a credit card or library card and pry the door open...worked every time for me
Old Jan 21, 2013 | 02:20 PM
danike's Avatar
yea, i usually take an old credit card and wedge it in hoping it stays wedged long enough for me to side step and press the gas lid release button on the driver side floor. It is a pain in the butt.
girth5785
Aug 19, 2014 07:56 PM
imhenryd
22
Mar 25, 2014 03:55 PM
Evo_Vinh
Mar 20, 2013 01:31 PM
EvoAznBoi
Nov 16, 2011 03:35 PM
Waz996
15
Jun 30, 2008 11:12 AM
