Full X turbo swap
Old Jul 8, 2014, 10:41 AM
chrichian's Avatar
Full X turbo swap
I plan to do a full x turbo swap. Now I have a question about air intake.
Since I run in cold climates in the winter, I need a big battery. So the question is can I use a Ralliart air intake on an evo x turbo or do I have an intake that is the evo x and move the battery? Here's a link to the intake I was thinking of.
http://www.lancershop.com/customer/p...881&quantity=1
Old Jul 8, 2014, 03:53 PM
joseph15712's Avatar
My set up is AEM cold air intake for Ra with adapter from RRE(Road Race Engineering), you need email or call them to order
Old Jul 8, 2014, 09:37 PM
spekil's Avatar
If you're going for the Evo X turbo swap, you should buy the intake for evo x. Just to avoid the worries of looking for the right fitment. You'll be using the evo x turbo inlet elbow pipe anyways.
I'm not too sure about the fitment issue you'll have with the intake you wanted though. I did relocate my battery in the trunk so I didn't have to worry about my intake system fitment issue. Search around. I thought, I saw somebody used a small battery instead and he was able to fit an aftermarket SRI.
Old Jul 9, 2014, 03:32 AM
chrichian's Avatar
Ok thanks for the reply. Then I put the battery in the trunk, so I will not have to have any problem with if it fits or not.
Old Jul 9, 2014, 05:13 PM
spekil's Avatar
Yup! It's good weight distribution too.
Old Jul 10, 2014, 03:45 AM
JoshB's Avatar
Cbrd makes a special intake made for Ralliarts with evo x turbos who didn't want to relocate. That's the path I took.
Old Jul 11, 2014, 08:13 PM
robertg's Avatar
I did the same. It's been running fine. Tight fit though.
Old Jul 14, 2014, 05:41 PM
Bom's Evo's Avatar
I'm using a Perrin intake tube I cut down two inches at the compressor side. This along with the velocity stack maf adapter by CBRD with I think 4 inch K&N filter. It is also a tight fit and flush with the ecu harness and battery. It doesn't move at all. Cost me $120 for the setup. I might redo it when I feel like upgrading my intercooler and intake together.
Old Jul 14, 2014, 05:45 PM
Bom's Evo's Avatar
I don't think that would work.
You would need the MAF adapter and/or a smaller filter.
In addition, you probably need to cut pipe shorter right wear that vacuum pipe is.
Where the battery is now on the RA, is where the evo x intake would be.
Old Jul 14, 2014, 07:59 PM
spider21's Avatar
Just mount batter in back much better option.
Old Aug 11, 2014, 05:12 AM
hixlancer's Avatar
I bought a small battery and it did fine in the winter. We had some very cold winters in Kansas too. Battery has been in for 2 years and doesn't give me any trouble...best battery i've ever had.
Old Aug 12, 2014, 08:04 AM
Rahtid's Avatar
I also used a small battery and the ets evo x intake kit, I had a aluminum battery tray made for the battery
SilentSage32
Nov 17, 2016 06:42 PM
danike
Dec 11, 2014 08:57 PM
TouV
24
Sep 28, 2014 01:32 AM
ra_guy
32
Feb 22, 2013 10:48 PM
Mad_SB
Mar 10, 2011 04:12 AM
Quick Reply: Full X turbo swap
