Possible problem with the ETACS for the ACD.? - Help.!
Old Jan 17, 2011 | 07:19 AM
Lethal_1's Avatar
Exclamation Possible problem with the ETACS for the ACD.? - Help.!
Hi there ...
From what I understand, there are 2 ETACS in our RA.?
One for the wipers, headlights etc, & 1 for the ACD, is that right.?
Just wondering if anyone has come across the ACD Warning Light.? - Anyone know how to fix this.?
Went to get it fixed thru Mitsubishi, & they've given me the cold shoulder because my car's been 'modified'.?
I need to know how to fix this because Mitsubishi are the only ones with the MUT III Tool so we can reset or diagnose.?
I'm now going thru my current tuner, & the scantool he used (worth $10K) tested everything as good, except for an " ETACS Failure " error.??
2 tuners ago, somehow he managed to *crash* the main ECU in the engine bay, had it sent away, restored/recovered, re-installed, & finished the tune.!
My last tuner tuned the car with no probs, got OK numbers, but the same persistent ACD warning lights keep showing.? They said to take it to Mitsu (here we go again)
Anyway ... I want my ACD working properly again.! - How do I get this fixed.? - Suggestions please.?
Old Jan 17, 2011 | 07:38 AM
sstevojr's Avatar
EvoScan can read and clear codes. Read the code then look up what it pertains to...
Old Jan 17, 2011 | 08:25 PM
Lethal_1's Avatar
OK ...
Not wanting to goto Mitsubishi due to a BAD experience back in March 2010, I will go, just to get the trouble codes.!
I'll be back later today, if not b4 the end of the week if they'll fit me in.? - Cheers.!
Old Jan 19, 2011 | 05:23 AM
Lethal_1's Avatar
Arrow
### UPDATE ###
OK, went back to Mitsubishi, all good ...
Results from my Mitsubishi ACD / AWC diagnosis & report ...
Codes :
U1428, U0126, U0101, U0100, U0141, U0121, U0431, C1617 - All Codes Are Linked.!!
ACD / AWC fluid was topped up with 1/2 a litre from the boot ( from where I was watching )
______ No warning lights reappeared ... but ... the same codes came back instead.? _____
Old Feb 8, 2011 | 08:35 AM
keith.'s Avatar
Originally Posted by Lethal_1
### UPDATE ###
Codes :
I know late bump. Can you explain what fixed these codes?
Old Feb 8, 2011 | 04:35 PM
Lethal_1's Avatar
Unhappy
Well ... we don't know yet.? - Mitsubishi are being "very difficult" to put it politely ...
Initially it was fixed by topping up the ACD Fluid in the boot to the tune of 1/2Lt.?
All the codes were reset, test drive done, re-tested & the same codes re-appeared.?
T h o ... The ACD Warning Light has now disappeared, & I'm still driving 'my normal way' ...
The initial call was that I needed an AWC Computer, got advice elsewhere & he said NO it's not.!!
When I return back to Mitsu for the ECU reset, they said No, I'd need an ECU Compter,
PLUS an Emobiliser Computer, PLUS reset the Smart Key, before they can reset my ECU.? What the hell.?
The " U1428, U0126, U0101, U0100, U0141, U0121 " are all CAN Bus timeouts ...
The " U0431 " is an Over Voltage error. (at the time, I had LED reverse lights fitted, no load resistors)
The " C1617 " is an OverBoost error in the tuned map from my previous tuner.!
The difficult part is getting Mitsubishi to reset my ECU back to OEM & re-diagnose ...
Anyway ... I'm at a stalemate & now searching local boys in the racing arena to get my ECU reset as per Mitsu specs.
It's a simple procedure, shouldn't take 'that long' to actually reset, + with the added diagnosis & test drive, about an hour or so.?
Once the test come's back all clear, I can then go ahead & dyno tune the car & finish it off ...
So for now, I have 2 other avenue's to try 1st ... still waiting for a reply ...
Old Feb 9, 2011 | 05:38 AM
keith.'s Avatar
I am going to mitsubishi with the exact same issue, but i am on stock motor and stock parts no tune. I also have the recaro seat issue, and two recalls that need to be done. What do you think my plan of action should be?
Old Feb 9, 2011 | 07:56 AM
RGRA's Avatar
My apologies for thread jacking, but wanted to subscribe to this anyway , but what "recaro seat issue" are you referring to? And if you're completely stock, and have an issue like this...go straight to mitsu!
Old Feb 9, 2011 | 08:03 AM
RGRA's Avatar
Also wanted to point out I had a steering wheel tilt (or angle maybe) sensor go in my RA, it was located between the steering wheel and the column/tree. With that sensor out, my ACD went ape sh*t. My RA was virtually un-drivable though, and had to get towed to the dealer. Just wanted to point out that the ACD & AWC pull info from sensors all over the car, so one bad sensor could be your problem...
Old Feb 9, 2011 | 01:47 PM
sstevojr's Avatar
What "Recaro seat issue"....?
Old Feb 9, 2011 | 02:19 PM
toredefine's Avatar
Possibly from the staples coming apart and loosening the fabric on the seats? I know that was an issue.
Old Feb 9, 2011 | 04:16 PM
keith.'s Avatar
Yup...both my local Mitsubishi dealers are being a pain tho. They want to keep it for 3-4 days no loaner car
Edit...I also had exhaust but I went back to stock exhaust last night...
lancer0220
Evo X How Tos / Installations
138
Nov 15, 2020 01:47 PM
Michael Roestel
Sep 21, 2017 08:00 AM
blackmambe_evo7
Sep 13, 2016 06:54 AM
al3lwan
Jan 31, 2014 10:29 PM
esevo
Dec 30, 2012 04:29 PM
