Boost pill
You won't notice much, if any change when replacing just the fmic. If you add in a hard upper pipe when you foo the install you may notice some improved boost response.
Did you go from cruising (5th or 6th gear) ane just floor it? Our cars have a real problem with this and will throw into limp mode very easily when it happens. It's a MAF sensor correlation issue that most people delete when tuning
I'm planning on getting the entire setup off an EVO X since it's a perfect fit for the RA. I was trying to decide whether or not I'd see any benefit that makes it worth doing now as opposed to later when I put in a stock EVO X turbo. It would be easier to do that all at the same time.
As far as noticing a difference, I didn't notice much. An intercooler doesn't really help produce more power rather it helps maintain it. As far as with warranty goes our cars are meant to be modded IMO and Mitsubishi knows that. The best thing to do if your worried about warranty issues is to call your dealership and literally straight up ask them, "If I do this will you warranty my car still?". Some dealerships accept mods and other will tell you to take a hike.
If you track the car I would look into getting a trans cooler and even maybe even look at upgrading it: http://www.jackstransmissions.com/co...evo-mr-6-speed
I love the car but the repair cost on this transmission scares me. If I feel confident that the money spent upgrading the SST @ 60k will significantly increase the lifespan of it I think it might be a worthwhile expense even though I don't plan on taking my car to the track. Getting it cracked open at 60k to beef it up and look for any potential damage seems like a good investment if I plan to own this car until it dies. Gotta swap the fluid at 60k anyway.
I'm hoping that as I get closer to my drivetrain expiring we'll have more info about SST reliability.
https://www.evolutionm.net/forums/09...-metering.html
And
https://www.evolutionm.net/forums/09...t-problem.html
And
https://www.evolutionm.net/forums/09...ml#post8551277
And
And
mfp5011
11
Jun 17, 2010 11:55 AM
