How to: Upper/Lower IC pipes & EvoX Intercooler
Old Dec 6, 2013 | 04:08 PM
  #211
pepsi_merch's Avatar
fail, :facepalm: i just went to page 13 and saw some pics
Old Feb 4, 2014 | 02:22 AM
  #212
Brian L's Avatar
Evo X licp to RA hose fitment question.
I am in the process of gathering the parts for the RA to X i/c change over. I have the X i/c and couplers and the X stock aluminium licp.
My question is about the hose that then runs from the licp up to the throttle body/manifold. Will the Evo x licp fit this RA hose with no problems or is the diameter different ?
Hope this makes sense.
Cheers
Brian.
Old Feb 4, 2014 | 08:42 PM
  #213
neogeo64's Avatar
Cheers
Brian.
I used Stock Evo BOV hose and cut it to keep the Stock BOV location on the RA. Connecting the lower curved part of the hose to the EVO X LICP your able to go around the battery tray. You can cut it like i did below or keep it full length and position the BOV more towards the rear like the EVO X.
Old Feb 5, 2014 | 01:16 AM
  #214
Brian L's Avatar
Cheers for the reply.
I obviously didn't explain it quite clearly enough but you picture helps.
It's not the bov hose but the other one from the licp, in your pic it is behind the bov hose, the wider hose with the 'collar' just below the bend the bend.
This I take it is the oem RA hose and it fits the Evo x licp with no problem ?
Thanks
Brian.
Old Feb 5, 2014 | 10:20 PM
  #215
neogeo64's Avatar
Yes the RA and Evo X share that same rubber licp section.
Old Feb 6, 2014 | 01:34 AM
  #216
Brian L's Avatar
Thank You.
Brian.
Old Feb 9, 2014 | 01:14 PM
  #217
Rex87's Avatar
Wish this helpful photo got posted before I went and bought an aftermarket LICP. Now I've got a spare LICP lol
Old Feb 10, 2014 | 12:04 PM
  #218
Veronica's Avatar
...and remember - you need an EVO X LICP from a MR (not a GSR).
Old Feb 10, 2014 | 02:31 PM
  #219
Brian L's Avatar
Cheers Veronica, only problems are
1 I've already got the LICP and no idea what it is from apart from Evo X !
2 Not coming from a Mitsubishi background at all I have no idea if MR or GSR spec cars are/were sold in the UK.
I shall see how I get on with what I have
Cheers
Brian.
Old Mar 10, 2014 | 02:03 PM
  #220
JayK's Avatar
This write up helped a ton when i did my FMIC and UICP. Thanks for posting!
Old May 14, 2014 | 10:51 AM
  #221
BlackMamba88's Avatar
Ditto. Thanks for the write-up!
Old Aug 14, 2014 | 06:06 AM
  #222
Glenn_Aus_RA's Avatar
What's the main difference between the two pipes?
Old Aug 14, 2014 | 06:42 AM
  #223
Veronica's Avatar
The GSR doesn't have the 'dent' to accommodate the MR's cooler.
The aftermarket LICP I was looking at said "GSR-Only" but most aftermarket do not make that distinction...
I apologize that I do not have a better answer...
Old Aug 14, 2014 | 03:25 PM
  #224
Ahhhk. Cheers
Yeah, I've only seen one after market LICP that actually makes the distinction.
Old Aug 16, 2014 | 04:10 PM
  #225
WookieBlue's Avatar
you sir are a savior!
