HOW TO: Replace Fog Lights for $16
Old Apr 12, 2015 | 06:29 PM
GetFoxed's Avatar
If you're reading this, then this is probably your situation...and here is how to fix it for cheap. $34 total = $17 ea.
Ralliart / EVO X broken fog lights
Disclaimer: Continue at your own risk. I am not responsible for any damages, injuries, etc. that may befall you or anything you possess/encounter/contact/borrow/fondle/whatever while attempting to replicate my actions. This modification has worked for me, but it is not my fault or responsibility if you attempt this modification and experience negative consequences. Be aware and informed of your actions and all should go well.
Step 1) Source for the replacement Fog lights http://www.ebay.com/itm/Ford-Focus-Explorer-Mustang-Ranger-Clear-Fog-Lights-Pair-RH-LH-Right-Left-/231523203446?vxp=mtr
Step 2) Remove the old broken fog lights. Check this thread to explain this.
https://www.evolutionm.net/forums/09...ht-lenses.html
Step 3) Get the Tools you need:
-Sharp Razor Blade
-Plyers
-Phillips Screw Driver, or drill driver with Phillips #2 Tip
-Drill
-Drill bits: 5/32", 3/16", and 1/4"
Tools
Drill Bits
Step 4) Remove Plastic Tabs shown in pics, use plyers to remove main chunks of plastic tabs and then use knife to clean it up
Remove plastic tabs with plyers & razor blade
Removing Plastic Tabs with plyers
Clean Up the parts you removed with the razor blade
Step 5) Line Up the trimmed housing in the fog light socket in the bumper, mark the tabs with where you will need to drill the new holes to fit.
Pull the new fog light out of the socket and drill the holes. It should fit per the pictures here.
Mark Holes
Drill / Ream & Test Fit, using the different bits noted above.
It should look like this.
Step 6) Test Fit, once happy with the fit, plug in the light, using factory screws, mount the light back into place. (Now is the time to test to make sure your connections are good, aka the lights work.)
Test Fit, and re-mount
Mount using factory hardware, in the factory holes.
Step 7) Snap the plastic fog light trim into place, a secure using factory hardware.
Snap Trim into place & use screw to mount
Lens will be approx 3/16" back from trim.
Lens will be approx 3/16" back from trim. (finger nail for reference)
Step 8) Clean Up & Drink some beers. Total project time: 30 mins (no beer) 2 hours, max (drinking beers).
Finished.
Finished Pic.
Credits: Credit goes to: neogeo64 and his post: https://www.evolutionm.net/forums/09...lass-16-a.html
I just installed my way this weekend, if it doesn't work out, I will pop the lenses and use the housing as neogeo64's method shows.
Thanks & Good Luck, If you have success or questions, please post below with pics.
Old Apr 14, 2015 | 08:39 AM
Zippy452's Avatar
is there a noticable difference between these housings your got and the oem? besides the modifiying you showed. Do the OEM sit flush or look different?
Old Apr 15, 2015 | 04:09 AM
GetFoxed's Avatar
Sit flush, no noticeable difference at all... Used them last night, and they are clear and work great!! I am very happy with them so far.
Old Apr 20, 2015 | 08:58 AM
Zippy452's Avatar
so your satified with the ones you linked to and see no need to swap the glass to the OEM housings? If so I may just go your route as it's easier and quicker. I mean is there any difference between the OEM housings and these that I would notice?
Also if it sits flush what is with the gap in the step 7 photo is seems to have?
Is that cause you didn't pop in the cover yet?
Old Apr 20, 2015 | 09:17 AM
GetFoxed's Avatar
As it sits, finished, and directly under the photo it states " Lens will be approx 3/16" back from trim. (finger nail for reference)" That is its final resting place, the glass does not touch the black plastic of the trim. Last Pic of Step 7 & 1st pic of Step 8 is the best reference for how they look completed.
I like them, they work great, no issues so far. They look completely stock from the exterior. You'd have to post a pic of your car's broken lights for me to compare, I don't remember what the stock looks like in reference to this.
There is always the other option of spending days, soaking lights, cutting and gluing. But I can deal with 3/16" of an inch, for not spending days on a project.
Old Apr 22, 2015 | 11:04 AM
neogeo64's Avatar
Yeah this was the route I originally was going to go but still wanted the ability to control the height adjust from the access hole. but most will set and forget so this method is cheaper and faster if you don't care about that.
Old Apr 27, 2015 | 12:57 PM
Ralliheart's Avatar
Another way is just breaking out the glass, removing the black sealant and securing new pieces of glass (can be purchased from a local glass grinder for $10-$20) to the housing with high temperature caulking/sealant. Easy $25 fix and the lens sits flush against the fog light surround. I replaced bulbs with LED's to be on the safe side heat wise.
Old Apr 28, 2015 | 09:02 AM
Zippy452's Avatar
i've heard of people getting glass cut but i'm not sure where to find someone around me to do it. I've tried googling glass shops and glass cutters but no dice. I only get auto body and glass shops (not sure fi they would be of help as I bet all glass they just order from dealers) and a giggles (google it if ya don't know what that is lol)
any suggestions on the glass route? wonder if i could find some lexan too.
Old Apr 28, 2015 | 10:49 AM
neogeo64's Avatar
yeah all the local glass companies around me will not cut 1/4" 3.5" round circles either.
If you want these to sit more flush you can simply add washers to the back of the tabs when screwing on the lights.
Old Apr 29, 2015 | 03:46 AM
Ralliheart's Avatar
Just go to a local store that frames pictures and ask them where they source their glass. That's what I did because I got nothing as well when I was searching on the line.
Old Apr 30, 2015 | 09:21 AM
Zippy452's Avatar
that might be a idea neo. i think i'm gonna try to do the glass route if i can. right now i only have one fog light broke so it would be cheaper. love the help. ty
Old Aug 12, 2019 | 06:40 PM
GetFoxed's Avatar
Update!!
Now on Amazon: $45.99 for the pair with bulbs included. Exact stock replacement, no modifications needed. Pictures of them installed here.
https://www.amazon.com/gp/product/B072TYFLFG/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B072TYFLFG/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
Fog Light Passenger Side
Fog Light Drivers Side
FiReBReTHa
Lancer How Tos / Installations
Jul 9, 2020 06:03 PM
iEvoVII
Evo X How Tos / Installations
May 18, 2015 12:58 PM
insomniac_evo
04-06 Lancer Ralliart How To Requests / Questions / Tips
21
May 9, 2014 02:09 PM
Locdizzel
Mar 21, 2013 09:32 AM
insomniac_evo
Jan 22, 2007 02:59 PM
