09+ Ralliart Show and Shine Post your pictures, photoshops, and videos!
Painted nose
Old Jun 21, 2009 | 11:01 AM
  #76
07outty's Avatar
i have used vinyl , primer/paint , black-out tape , and plastidip on various parts on
a lot of different cars.
plastidip is durable...better than properly done primer/paint ? ? ? not really.
the beauty of plastidip, is any time you want , you can peel it off of the surface you
applied it to.
Old Jun 21, 2009 | 11:49 AM
  #77
PRican_480's Avatar
good job man looks way better IMHO
Old Jun 21, 2009 | 01:32 PM
  #78
08Lancer89's Avatar
Originally Posted by Drows
I'm guessing it's more durable then paint. Paint would chip/peel easier maybe? (I've never seen plasti-dip before, but heard it's supposed to be better then painting.
interesting
Old Jun 21, 2009 | 04:11 PM
  #79
hibby's Avatar
Originally Posted by Cesarn2928
oh snap! then i will try da tape... just to see how red n black lookz
You'll probably have to redo it from time to time -- rocks and road debris will probably damage it eventually -- but it's fairly durable.
Old Jun 21, 2009 | 06:52 PM
  #80
Cesarn2928's Avatar
how much dat tape cost? and do u need something special to put it?
Old Jun 21, 2009 | 07:57 PM
  #81
hibby's Avatar
Don't know how much it's going to cost -- shouldn't be a fortune.
You'll probably want a spray bottle of water with a drop or two of Ivory dish soap in it to make the vinyl easier to move around, but don't use a lot...too much makes it hard to get the stuff to stay put, and you can get water trapped underneath.
(Other people may have their own methods of application, but that's how I'd probably try to do it.)
MAKE SURE YOUR SURFACE IS CLEAN BEFORE YOU PUT THE VINYL ON.
Old Jun 21, 2009 | 08:41 PM
  #82
jdavidic's Avatar
Just So you guys could see what TB Looks like with the nose painted....If you want to see more pics just go to my signature link
Old Jun 22, 2009 | 01:24 PM
  #83
08Lancer89's Avatar
too much black, I would have left it chrome on the black but thats just my taste.
Old Jun 22, 2009 | 01:38 PM
  #84
GiLizILL's Avatar
dark tint and black rims,,then your set
Old Jun 22, 2009 | 02:01 PM
  #85
jdavidic's Avatar
I just always felt Chrome belongs on lowriders or harleys.
Old Jun 22, 2009 | 02:54 PM
  #86
07outty's Avatar
the black RAs' may look good with the center section ( including the ring )
being painted a very dark matt gray.....
Old Jun 22, 2009 | 03:20 PM
  #87
GiLizILL's Avatar
I just always felt Crome belongs on lowriders or harleys.
and audi's
Old Jun 22, 2009 | 11:41 PM
  #88
GraphiteRalli's Avatar
Looks sick my friend. Where abouts in NY are you located? I'd like to take a closer look and meet up with some other local RA's.;
Old Jun 23, 2009 | 05:48 AM
  #89
jdavidic's Avatar
I'm in Watertown its up by FT Drum.
Old Jun 24, 2009 | 03:50 AM
  #90
Cesarn2928's Avatar
Originally Posted by MambaRA
Alright guys sorry just got outta work so I couldn't post but I used krylon black satin(I had a feeling the flat wouldn't work as nice) and I used a krylon rust free primer. I took the chrome ring off and it was a pain. I first took off the plastic tube that leads to the intake box. After that is off I took off the plastic shroud that is on the inside. Once this shroud is off you will see all the silver screws on the inside. This part if fairly easy, just have a stubby phillips. There should be a total of 10 silver screws(sadly I was missing one). Once all these are taken out its time for the bottom. I went under the car and used a 10mm socket to remove 5 bolts under the car. (you will see the shroud underneath) once the bolts are undone there are 4 black clips, 2 on each side near the wheels. Once all the clips and bolts are off I stuck my hand in under the intercooler and undid the screws to the black bottom grate. Once those are undone there are 2 bolts of the outside. You will need a socket extender. When these are out carefully pull out the grate. This gives you access to the bottom to take out the rest of the screws to the chrome ring. once all the screws are out slowly pull off the chrome ring. From here i used a high grit sandpaper to take off the finish. This took me about an hour to do a really nice job. I forgot to get emery cloth to wet sand. Once sanded i just sprayed it and let it cure for a few hours and it was ready. If you guys want pics and a more descriptive how to let me know.
do u also paint the middle cap? or just the ring?
