Patient Mr. White Rabbit on operating table
Old Jul 14, 2005 | 06:24 PM
  #31
taenaive's Avatar
I think it may not that easy to gain from modding mitsu's original turbo design. you can do blow more air. But that air will be hot !
  #32
TurboTodd's Avatar
i hope you guys get things sorted out. i made some base line pulls last night in 90 degree heat and made 340hp on the first pull with 91 octane with water/alky. subsequent pulls netted more torque but hp remained about the same. the shop owner told me his mustang dyno reads lower than the dynojet. he thinks its actually 365-370. i was at 25 psi. the works has done a great job helping me with the custom flash. i'm trying for 350 but i'm not too sure it will happen. i am very pleased with the performance improvement.
todd
Old Jul 14, 2005 | 06:27 PM
  #33
Warrtalon's Avatar
Originally Posted by Widebandphillip
To reiterate since my post was deleted, why was the tune stated as spot on and later determined as too aggressive?
Phillip, he didn't say "too" aggressive, he just said it was "very" aggressive. Aggressive can also be "spot on." I think what Al was saying is that it wasn't like the tune was set conservatively like a basic, everyday high 10 AFR flash, but rather tuned to actually make as much power as possible without being too lean.
On another note, I don't see how 315whp is "crap" or "bad" for those mods. I'd like to see how many other 03/04s there are out there with 315whp on only a TBE/MBC. On an 05, those whp would be about right for those mods on an aggressive tune, though. How much better is the WR supposed to be than the 05 turbo at pump gas boost levels?
Old Jul 14, 2005 | 06:29 PM
  #34
johnjonfenomeno's Avatar
Todd please post your results on this thread since you are a flash customer with this upgrade.. I want to get all the results of flashed rabbits consolidated
https://www.evolutionm.net/forums/sh...d.php?t=148666
  #35
titaniumkingpin's Avatar
i understand that this turbo works well with higher octane and more boost but what about people who want to run ~21psi w/o alky?
I guess i should look elsewhere.
j8 - what gives for a comment like that?
Old Jul 14, 2005 | 06:31 PM
  #36
mike 99gsx's Avatar
Originally Posted by 1.8t
For some reason I am not that surprised.....I have had a hunch since this turbo came out. NOW I AM NOT SAYING IT WON'T MAKE THE NUMBERS, but I suspect reflash WR users to make make far less whp than the boys over at switzer with their AEM EMS on the car.
Why is this? I realize there is a power benefit to the EMS simply based on the fact that you can go speed density and remove the MAF. However, if we are just talking about peak dyno numbers, can there really be a 70+hp discrepancy between the EMS and the ability to maniupluate timing and fuel maps via reflashing?
Perhaps I am wrong. I have been curious for a while now to see what will happen when people try to reflash ECUs with larger turbos. The problem has been, in general, that most people move to an EMS once they've upgraded turbos so there isn't a ton of data out there.
  #37
KILTERMAN's Avatar
Kinda seems like hype , just like in the for sale section , If it sounds too good to be true it probably is.
Old Jul 14, 2005 | 06:32 PM
  #38
For those who wonder... That same car made 305 whp on TT dyno before the tortoise
  #39
midwestmonster's Avatar
Originally Posted by j8
Guys,
We just had 5 WR's tuned here in Texas last weekend. Two of which will be on dyno's soon. After talking to everyone, the bunny tuned on Alky by far was the best bunny of all. That turbo seems to just come alive after 23psi. The bunny on Alky will be runing next Wednesday at our local track. Even though it is hot as hell here in Texas I would not be suprised if he runs some high 11's. I guess we will wait and see.
But aren't there a lot of people on the stock turbo running high 11's? I would hope this turbo would do better than high 11's.....
Old Jul 14, 2005 | 06:33 PM
  #40
KILTERMAN's Avatar
Good question. I have also pondered why this is. Maybe Al can chime in and shed some light
  #41
Switzer needs to try this experiment on a flash
Old Jul 14, 2005 | 06:37 PM
  #42
gofaster87's Avatar
Ive heard of several people flashing an ecu to accomodate a 35r. It is possible but might not be the best path to take.
  #43
mike 99gsx's Avatar
Maybe Tym should start reflashing his own ECUs and results would be different
Old Jul 14, 2005 | 06:38 PM
  #44
evoviiiyou's Avatar
hehe...
Old Jul 14, 2005 | 06:39 PM
  #45
TurboTodd's Avatar
everyone relax here. the rabbit has made a substantial power increase. to get the most out of it you need to run higher boost levels. this is expected from a small frame turbo like this. easy 11 second car on 91 at 3425 lbs. w/driver is very impressive when in my case it looks like i have only a k/n filter under the hood and its my wifes daily driver.
