Evo IX 2-byte Load & Lean Spool for Dummies
Old Apr 20, 2007 | 04:10 PM
  #31
Tuner@Swift's Avatar
Originally Posted by TouringBubble
I just checked again.
I have the original values as:
2-byte High - 3EE86 - 27169
2-byte low - 3EE8A - 27168
Incorrect 2-byte low - 3EE6A - 0
Can anyone verify?
Yes, I already said that the value @ 3ee6a was set to 27168 in my original, unadulterated ROM.
Old Apr 20, 2007 | 04:18 PM
  #32
TouringBubble's Avatar
Yes, but our results differ so I asked for more input.
Old Apr 20, 2007 | 05:54 PM
  #33
I have checked various evo IX '15' roms that I have saved from people I know. Of the 6 roms I have saved, half have 0 @ 3ee6a and the other half have 27168. So I guess it really doesn't matter.
Old Apr 21, 2007 | 08:26 AM
  #34
That is pretty odd. Does it seem strange to you that 3EE8A and 3EE6A have the same value in some ROMs?
Old Apr 21, 2007 | 11:47 PM
  #35
lapulapu's Avatar
Is this how the 2 byte RPM suppost to look like?
RPMMUT2Byte
1840000
1824000
1824000
1840000
1824000
1824000
1840000
1840000
1824000
1824000
1840000
1824000
1824000
1840000
1824000
1824000
1824000
1840000
1584000
1824000
1824000
1824000
1568000
1840000
1840000
1824000
1840000
1824000
1840000
1840000
1824000
1840000
1824000
1840000
1840000
1840000
1824000
1824000
1840000
1840000
1824000
1840000
1824000
1840000
1840000
1824000
1840000
1824000
1840000
1824000
1840000
1824000
1840000
1824000
1840000
1824000
1824000
1840000
1824000
1840000
1824000
1840000
1840000
1824000
1840000
1840000
1824000
1840000
1824000
1840000
1840000
1824000
1824000
1824000
1824000
1840000
1824000
1568000
1840000
1824000
1824000
1840000
1824000
1840000
1824000
1824000
1824000
1824000
1840000
1840000
1824000
1824000
1824000
1824000
1840000
1824000
1824000
1840000
1568000
1840000
1840000
1824000
1840000
1840000
1824000
1824000
1824000
1824000
1808000
1792000
1808000
1792000
1792000
1808000
1792000
1808000
1792000
1808000
1792000
1792000
1808000
1792000
1792000
1808000
1792000
Old Apr 22, 2007 | 06:38 PM
  #36
This thread is for 2-byte load and does not address the mods needed for the 2-byte RPM. I understand that you need to modify your definition file for the RPM mod as well, which would explain your odd numbers. I'm interested in a write up on that one as well if anyone would like to take the time to put it together. A search returns no useful info on the 2-byte RPM mod.
Old Apr 24, 2007 | 12:40 AM
  #37
coolguycooz's Avatar
Did somebody have the code posted for most evo 8 roms? I have an 05 evo8
my rom ID is 96940011
Old Apr 24, 2007 | 08:40 AM
  #38
Pd1's Avatar
Pd1
RPMMUT2Byte
1840000
1824000
1824000
1840000
1824000
1792000
1792000
1808000
1792000
1792000
1808000
1792000
No. Go through the instructions and try again. Your numbers should be in the ballpark of your LoadCalc numbers.
EDIT: My mistake...I thought you were referring to the 2-byte load, as this thread doesn't discuss the 2-byte RPM.
Old Apr 24, 2007 | 09:38 AM
  #39
travman's Avatar
where are these instructions for 2 byte rpm? I havent been able to find any for the IX........
Old Apr 29, 2007 | 01:01 PM
  #40
Mr. Evo IX's Avatar
For 88590013 and 88590014 Evo IX ROMS use low byte hex 3EE6A= decimal 27458 and high byte hex 3EE66= decimal 27459.
Old Apr 30, 2007 | 03:54 PM
  #41
nj1266's Avatar
Isn't there another way to do the lean spool enable/disable?
This is how Evo Kid did it. Can we do it that way?
Open up a EVO IX rom with ECUFlash.
Go to "boost enhancement (anti-lag) Stop RPM"
Right click on it and select "edit map"
Change the address to "1284", click apply, then OK
Make both the "boost enhancement (anti-lag) Stop RPM" and the "boost enhancement (anti-lag) Start RPM"
the same. I set both at 1500rpm.
Seems to be much easier than the way it was done here. Can I do that on my 15 numbered rom? I have 1280 for start and 1282 for stop.
Old May 1, 2007 | 09:15 AM
  #42
kreionic's Avatar
I think I have an issues. I entered the new data in the XML and then I open ecuflash with a 15 rom and I get "unknown rom image" "the wizard will generate the basic rom definition information needed to start working with this rom image"
I can pick from
Defined from scratch
copied from the definition below
Inherited from definition below
what do I do or did do something wrong?
Old May 1, 2007 | 09:36 AM
  #43
Pd1's Avatar
Pd1
I can pick from
Yes. Try again, and just follow each step exactly as it's laid out in the original post. It should work. Several here have had success with these instructions.
Old May 1, 2007 | 09:57 AM
  #44
nj1266's Avatar
Would someone please answer my question posted in #41?
Old May 1, 2007 | 11:21 AM
  #45
mrfred's Avatar
The only way to disable lean spool is to set the enable/disable to the same rpm.
