Evo IX 2-byte Load & Lean Spool for Dummies
Part of the issue is its the EDM rom and most people here have experience with either the JDM or the USDM. Its not quite just a V16 of what we have though. It seems that the addresses for OBDII related functions as well as Lean Spool are the same more or less between all the ROMS only being dependant on year (03-04 is different than 05-06 for lean spool).
If you understand how to add new definitions, add them to your ROM and see if the values correlate as far as lean spool and the O2 addresses. As far as 2 byte load that is also outside my frame of reference.
JB
JB
Thanks for the relpy. I am interested in 2 bytes load, but not in lean spool disable.
I have checked my ROM image and in all addresses listed I have no data (FF FF).
I think I will survive without it...
ok so i've been playing around with this for quite some time...i've tryed several times but am unsuccessful at getting the new parameters to pop up everytime i paste the definitions to the end of the script. i can't see what i did wrong, but did i enter the def. in the wrong spot??? here's a list of the script i'm trying to edit on my 15rom. (evo IX). if someone can point me in the right direction i'd greatly appreciate it. thanx...
<table name="High Octane Fuel Map" address="2dbd">
<table name="Engine Load" address="6ec8" elements="20" scaling="Load"/>
<table name="RPM" address="6ea0" elements="15"/>
</table>
<table name="Low Octane Fuel Map" address="2ef5">
</table>
<table name="High Octane Ignition Map 1" address="33e9">
<table name="Engine Load" address="6f2c" elements="21" scaling="Load"/>
<table name="RPM" address="6efa" elements="20"/>
</table>
<table name="Low Octane Ignition Map 1" address="3599">
</table>
<table name="High Octane Ignition Map 2" address="5523">
</table>
<table name="Low Octane Ignition Map 2" address="56d3">
</table>
<table name="High Octane Ignition Map 3" address="5a33">
</table>
<table name="Low Octane Ignition Map 3" address="5be3">
</table>
<table name="VVT Map 2 (Not Used) Future Use" address="536b">
<table name="Engine Load" address="7a64" elements="20" scaling="Load"/>
<table name="RPM" address="7a96" elements="16"/>
</table>
<table name="VVT Map 1 (Main)" address="68bd" scaling="ValveTiming">
</table>
<table name="Injector Battery Voltage Latency Compensation" address="31d4">
<table name="Battery Voltage" address="6df4" elements="7"/>
</table>
<table name="Accel Enrichment" address="3278">
<table name="RPM" address="6c26" elements="15"/>
</table>
<table name="Rev Limit" address="118c" scaling="RPMLimit"/>
<table name="Stationary Rev Limit" address="2798" scaling="RPMStatLimit"/>
<table name="Boost Delay Timer" address="119a" scaling="Time"/>
<table name="Injector size scaling" address="1106" scaling="InjectorScaling"/>
<table name="Boost Control Load Offset" address="1670"/>
<table name="Turbo Boost Error Correction" address="3f20">
<table name="Boost Error" address="7258" elements="17"/>
</table>
<table name="Boost Desired Engine Load # 1" address="3f80">
<table name="RPM" address="722e" elements="16"/>
</table>
<table name="Boost Desired Engine Load # 2" address="3f96">
<table name="RPM" address="722e" elements="16" scaling="RPM"/>
</table>
<table name="Boost Desired Engine Load # 3" address="3fb2">
</table>
<table name="Max Wastegate Duty # 1" address="3f38">
</table>
<table name="Max Wastegate Duty # 2" address="3f4e">
</table>
<table name="Max Wastegate Duty # 3" address="3f6a">
</table>
<table name="Wastegate Solenoid Activation RPM-Active" address="1668"/>
<table name="Wastegate Solenoid Activation RPM-De-activate" address="166a"/>
<table name="Wastegate Solenoid De-activation RPM-De-activate" address="166c"/>
<table name="Wastegate Solenoid De-activation RPM-Re-activate" address="166e"/>
<table name="Open Loop Load # 1" address="3060">
<table name="RPM" address="6b98" elements="16"/>
</table>
<table name="Open Loop Load # 2" address="3076">
</table>
<table name="Open Loop Throttle Low Load" address="3092">
</table>
<table name="Open Loop Throttle High Load" address="30a8">
</table>
<table name="IC Relay Timer ON Mode Switch Time" address="20a4"/>
<table name="IC Relay Timer Control RPM" address="20a6" scaling="RPMStatLimit"/>
<table name="IC Relay Timer Control Water Temp Hi" address="20a8"/>
<table name="IC Relay Timer Control Water Temp Lo" address="20aa"/>
<table name="IC Relay Control Vehicle Speed" address="20ac"/>
<table name="IC Relay Control EV" address="20ae"/>
<table name="IC Relay Timer On Time" address="20b0"/>
<table name="IC Relay Timer Off Time" address="20b2"/>
<table name="IC Relay Timer Control Judgement Hi" address="20be"/>
<table name="IC Relay Timer Control Judgement Lo" address="20c0"/>
<table name="IC Relay Timer Air Temp" address="20c2"/>
<table name="Desired ISCV intial step position with AC off-Neutral" address="3d24">
<table name="Engine Temp" address="70c2" elements="8"/>
</table>
<table name="Desired ISCV intial step position with AC off-Drive" address="3d38">
</table>
<table name="Desired ISCV intial step position with AC on-Neutral" address="3d4c">
</table>
<table name="Desired Idle RPM-Neutral" address="3d60">
</table>
<table name="Desired Idle RPM-Drive" address="3d6e">
</table>
<table name="Boost Limit" address="3050">
<table name="RPM" address="76b0" elements="9"/>
</table>
<table name="Idle Stepper Lookup Table" address="3e31">
<table name="Throttle Postion" address="7164" scaling="uint16"/>
<table name="RPM" address="717e" scaling="RPM"/>
</table>
<table name="MAF Scaling" address="2d06">
<table name="Load" address="6da4"/>
</table>
<table name="MAF Smoothing Table" address="2d22">
</table>
<table name="Air Temperature Compensation" address="2d3e">
<table name="Degrees" address="7070"/>
</table>
<table name="Barometric Pressure Compensation" address="2d51">
<table name="Atmosphere Pressure" address="6d92"/>
<table name="RPM" address="6dd8"/>
</table>
<table name="MAF Size" address="110c"/>
<table name="MAF Sensor Filtering" address="1108">
<table name="Load"/>
</table>
<table name="Min Temp for Full Boost Control" address="1e26"/>
<table name="Boost Control Limiting Vehicle Speed" address="1e2a">
<table name="Condition"/>
</table>
<table name="Knock Sensor Filter Map 1" address="4361">
<table name="TAR" address="7356"/>
<table name="RPM" address="7316"/>
</table>
<table name="Knock Sensor Filter Map 2" address="441d">
</table>
<table name="Knock Sensor Filter Map 3" address="44d9">
</table>
<table name="Knock Sensor Filter Map 4" address="4595">
</table>
<table name="Knock Sensor Filter Map 5" address="4651">
</table>
<table name="Knock Sensor Filter Map 6" address="42a5">
</table>
<table name="Knock Sensor Filter Map 7" address="495b">
</table>
<table name="Knock Sensor Filter Map 8" address="4a17">
<table name="TAR" address="7356" elements="16"/>
</table>
<table name="Knock Sensor Filter Map 9" address="4ad3">
</table>
<table name="Knock Sensor Filter Map 10" address="4b8f">
</table>
<table name="Knock Sensor Filter Map 11" address="4c4b">
</table>
<table name="Knock Sensor Filter Map 12" address="4d07">
</table>
<table name="Boost Enhancement (Anti-lag) Stop RPM" address="1282"/>
<table name="Boost Enhancement (Anti-Lag) Start RPM" address="1280"/>
<table name="Speed Limit" address="118e">
</table>
<table name="2 byte load high bit" address="3EE86" category="Misc" type="1D" level="1" scaling="uint16" />
<table name="2 byte load low bit" address="3EE8A" category="Misc" type="1D" level="1" scaling="uint16" />
</rom>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</rom>
</table>
</rom>
</table>
</rom>
yess!!!! problem solved....thanx mr.fred! haha now time for some fun logging
...i had it defaulted to beginner mode so everytime it started up the new script wouldn't show the 2 new options, but as soon as u told me to switch to developer, everything worked out fine.
Any more info on the EDM 88840016 ROM (2 byte load)?
Haven't quit understood all this yet, but when I log "Load MUT 2Byte Mod" I get some wierd values (between 2000-5000). Can someone confirm that these values are useless without doing the mod in the XML and ROM file? Haven't really seen any explanatory background info on the 2-byte load topic..
