Evo IX 2-byte Load & Lean Spool for Dummies
Hi
These are the lean spool address I've taken from my xml, seems to work OK but as ever make sure you check your AFRs out with a wideband
<table name="Lean Spool Start RPM" category="Misc" address="1680" type="1D" level="1" scaling="RPMStatLimit"/>
<table name="Lean Spool Stop RPM" category="Misc" address="1684" type="1D" level="1" scaling="RPMStatLimit"/>
MB
MB
Add these two entries to your 88840016.xml ROM file:
----- (don't include the "-----")
<table name="MUT00 2-byte load MSB" category="MUT" address="377fa" type="1D" level="1" scaling="Hex16"/>
<table name="MUT01 2-byte load LSB" category="MUT" address="377fe" type="1D" level="1" scaling="Hex16"/>
Then launch ECUFlash, open your ROM, and scroll down to the entries:
Change MUT00 from 6A09 to 6B22 (you'll have to enter it as 0x6B22).
Change MUT01 from 6A08 to 6B23 (use 0x.... again).
Save the ROM, and you're ready to upload it to your ECU.
Hi
MB
MB
If I "Enableleanspool" I'll need to recalibrate my AFR's? Is this correct?
It comes on from the factory. You made this mod so you could disable it (by setting the start and stop to be the same RPM). If you disable it, then yes you will have to adjust the fuel map to get your AFRs back up (they will be too rich).
Add these two entries to your 8840016.xml ROM file:
<table name="MUT00 2-byte load MSB" category="MUT" address="377fe" type="1D" level="1" scaling="Hex16"/>
<table name="MUT01 2-byte load LSB" category="MUT" address="37802" type="1D" level="1" scaling="Hex16"/>
Change MUT00 from 6A08 to 6B22 (you'll have to enter it as 0x6B22).
Change MUT01 from 6A11 to 6B23 (use 0x.... again).
Thanks mrfred
I will try this to the EDM rom
It works with following:
Values:
MUT00 from 6A09 to 6B22 (hex)
MUT01 from 6A08 to 6B23 (hex)
Tried at idle, cannot move the car for today...
It seems that you are hitting MUT01 and MUT02 instead of 00 and 01...
Values:
Values:
reflashed my previous rom and thank god car started.
I will give yours a bash and check
thank you
Stoopid question... maybe
Anybody knows if the lean spool function has anything to do with the solenoid placed in between the manifold and the FPR ?
I have noticed this set-up on every Evo (V up to IX) without finding any info about it ?
But as this solenoid is still there, not to my likee, I'm still wondering what this thing could be here for...?
Help
Hi I added:
<table name="2 byte load high bit" category="Misc" type="1D" address="3EE86" level="1" scaling="uint16"/>
<table name="2 byte load low bit" category="Misc" type="1D" address="3EE8A" level="1" scaling="uint16"/>
Right above the </rom> saved it. I opened ecuflash made sure developer mode was selected under the options menu and the new tables did not show under misc or any other category. I seem to be the first with this problem. I added other idle definitions a while back and those tables show up and work, so I know I put the code in the right place. Here is the xml so you can check it out for yourself. just re-save it as a xml, i changed it to txt to upload. Thanks
EDIT: Ok I fixed it. Last resort so I uninstalled ecuflash and deleted the entire folder, and reinstalled ecuflash and add the code into the xml and it worked. Weird glitch I guess, but figured I would post to help anyone else who may have this problem.
