Evo IX 2-byte Load & Lean Spool for Dummies
Old Nov 9, 2007 | 03:03 AM
  #166
awadkhan's Avatar
hmmm
a possible dumb question.... what is the remedy for 93660005?? do u apply the same xml as per 70008 one?? for evo8....
thanks
Old Dec 1, 2007 | 09:26 PM
  #167
nj1266's Avatar
nm...
Old Dec 18, 2007 | 06:28 AM
  #168
Gpunkt's Avatar
for 88840017:
<table name="MUT00 2-byte load MSB" category="MUT" address="37946" type="1D" level="1" scaling="Hex16"/>
<table name="MUT01 2-byte load LSB" category="MUT" address="3794a" type="1D" level="1" scaling="Hex16"/>
Values:
MUT00 from 6A09 to 6B22 (hex)
MUT01 from 6A08 to 6B23 (hex)
Old Dec 26, 2007 | 10:43 PM
  #169
Profoxcg's Avatar
what is this 2 byte load? can someone please explain?
Old Dec 27, 2007 | 08:09 AM
  #170
EVO8emUp's Avatar
Read the first post.
Old Jan 2, 2008 | 08:16 AM
  #171
DCsleeper's Avatar
Lean Spool Disable?
I followed the instructions for disabling lean spool according to option 1. Only I changed the addresses to 1680 and 1684 (since I have an VIII ROM 94710014). I input 48 into both tables to disable lean spool.
My question is that the original maps for boost enhancement start/stop still exist in the ROM. Do I have to do anything to these?
Old Jan 3, 2008 | 01:13 PM
  #172
Profoxcg's Avatar
Talking QUESTIONS to better understand tunning
From reading the whole thread I know the Lean spool - leans the AFR during spool 2500 - 7000 rpms by .7 - 1 point. why did the factory do this? rather than just disable it as we are doing?
When we disable it, we are going to be running .7 - 1.0 point richer than what the A/F MAP calls out for "on a stock evo" - so all we have to do it lean the map between 2500 - 7000 accordingly maybe by a whole 1.0 point or more.. ect...
What is "the spool area" of the maps? I rear sentence such as
12.5 during spool and 10.5 at WOT - what does this mean?
If we have a logger such a evocan or logwork which can trace a map, then we don't really need 2byte-load? or 2byte-rpm do we?
Old Jan 3, 2008 | 02:35 PM
  #173
burgers22's Avatar
The map tracing is most accurate when using 2 byte load rather than load calc, so though we maybe don't need to see 2 byte load displayed on the graph, it can be most helpful when using auto map tracing.
MB
Old Jan 3, 2008 | 02:45 PM
  #174
Profoxcg's Avatar
auto map tracing
what software has the feature ?
Old Jan 3, 2008 | 04:11 PM
  #175
burgers22's Avatar
Evoscan V 2.0 has map tracing.
MB
Old Jan 3, 2008 | 09:57 PM
  #176
Profoxcg's Avatar
MB
but its not real-time is it?
any how if I load the maptrace in evoscan then why would I need 2BL ?
Old Jan 4, 2008 | 12:54 AM
  #177
burgers22's Avatar
No it's not real time. 2 byte load can be used to trace the route of the load through the map, in the same way it would use load calc, but 2 byte is considered more accurate. How do you think Evoscan does the map tracing now?
MB
Old Jan 4, 2008 | 05:57 AM
  #178
DCsleeper's Avatar
Anyone have an answer to post #171?
Old Jan 4, 2008 | 07:15 AM
  #179
Profoxcg's Avatar
MB
I would love to see something real time. When I had my civic (ep3) I used something called K-pro from hondada.com. well this ecu thing had real time tracing, it was really cool becuse you could see the cell you are hitting at you log.
in Re: to 2BL - if were to not log either loadCalc or 2Byte load then the tracer would not work?
Old Feb 10, 2008 | 12:18 PM
  #180
Jack_of_Trades's Avatar
I'd suggest keeping your eyes on the road and inspecting your map tracer logs afterward
