Nolift to Shift??
Old Sep 27, 2007 | 08:13 PM
  #211
evoracingstar's Avatar
my buddy has it on his sti sounds bad a$$
Old Sep 27, 2007 | 08:14 PM
  #212
Jack_of_Trades's Avatar
heck yeah! How would i be able to set my evoscan to record that particular memory location?
Old Sep 27, 2007 | 08:22 PM
  #213
tephra's Avatar
94170008 0xFFFF88A3
94170014 0xFFFF88A3
94170015 0xFFFF88A3
88590015 0xFFFF6A35
96940011 0xFFFF88DF
88840016 0xFFFF6A1D
OK so same way that you do 2byte load... So setup MUT00 (or whatever) with the memory address from above, so if you are 94170008 set MUT00 to 0x88A3.
Then setup evoscan to log Mut00 as a single byte (not 2byte) and then log it.
When you get on the clutch it should read 0x1 and off should read 0x0. NOW there are other flags in there as well, ie acceleration is 0x16. So if you are on the accelerator AND the clutch it will read 0x17.
Cheers
D.
Old Sep 27, 2007 | 08:42 PM
  #214
dudical26's Avatar
Tephra-
So just to check what your saying here as I am a little confused, if I have evo9 ver15 then I add the following to EcuFlash definition
<table name="MUT00" category="MUT" address="88A3" type="1D" level="1" scaling="Hex16"/>
Add this to EvoScan, can you fill in the blank.
<DataListItem DataLog="N" Color="" Display="Clutch Switch" LogReference="ClutchSwitch" RequestID="??" RequestID2="??" Eval="" Unit="units" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="8000" ChartMin="0" ChartMax="8000" ScalingFactor="1" Notes=""/>
Thanks
Old Sep 27, 2007 | 08:46 PM
  #215
tephra's Avatar
nope
Dont add any new XML into EcuFlash - just go and change your MUT00 (in the mut table) inside EcuFlash to poing to 0x88A3
Inside EvoScan just add this:
<DataListItem DataLog="Y" Display="ClutchFlag" LogReference="ClutchFlag" RequestID="00" Eval="x" Unit="unit" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" Notes=""/>
Old Sep 27, 2007 | 09:05 PM
  #216
dudical26's Avatar
I don't see any MUT table??
Old Sep 27, 2007 | 09:12 PM
  #217
tephra's Avatar
GRRR You are 88590015 right? Add this to your XML in EcuFlash
<table name="MUT Table" category="Advanced" address="3ee84" type="3D" level="1" scaling="Hex16">
<table name="X" type="Static X Axis" elements="32">
<data>-</data>
<data>0</data>
<data>-</data>
<data>1</data>
<data>-</data>
<data>2</data>
<data>-</data>
<data>3</data>
<data>-</data>
<data>4</data>
<data>-</data>
<data>5</data>
<data>-</data>
<data>6</data>
<data>-</data>
<data>7</data>
<data>-</data>
<data>8</data>
<data>-</data>
<data>9</data>
<data>-</data>
<data>A</data>
<data>-</data>
<data>B</data>
<data>-</data>
<data>C</data>
<data>-</data>
<data>D</data>
<data>-</data>
<data>E</data>
<data>-</data>
<data>F</data>
</table>
<table name="Y" type="Static Y Axis" elements="16">
<data>0</data>
<data>1</data>
<data>2</data>
<data>3</data>
<data>4</data>
<data>5</data>
<data>6</data>
<data>7</data>
<data>8</data>
<data>9</data>
<data>A</data>
<data>B</data>
<data>C</data>
<data>D</data>
<data>E</data>
<data>F</data>
</table>
</table>
Old Sep 27, 2007 | 09:16 PM
  #218
dudical26's Avatar
very cool, thanks soo much.
Old Sep 27, 2007 | 09:48 PM
  #219
Dave, I give you so much credit for the massive amounts of patience you have. I have been using ECUFlash and evoscan for a little over a week now and its like greek to me, (though I'm not new to this stuff in general) yet you are always willing to help the newbies with the programming hurdles.
Old Jun 7, 2009 | 10:54 PM
  #220
fostytou's Avatar
EvoM Community Team
Originally Posted by dudical26
Tephra-
Thanks
Originally Posted by tephra
nope
Hate to bring this back from the dead, but I don't understand the x bits at all. Can someone explain/show me the correct x bit to log only clutch operation?
Thanks!
Old Jun 8, 2009 | 01:18 PM
  #221
fostytou's Avatar
EvoM Community Team
Thanks!
Ok, I think I've got it. The Evoscan formula for logging clutch discreetly with that MUT value at 00 is
Code:
<DataListItem DataLog="Y" Display="ClutchFlag" LogReference="ClutchFlag" RequestID="00" Eval="x bit 1" Unit="unit" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="1" ChartMin="0" ChartMax="1" Notes=""/>
And furthermore acceleration would be
Code:
<DataListItem DataLog="Y" Display="ClutchFlag" LogReference="ClutchFlag" RequestID="00" Eval="x bit 16" Unit="unit" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="1" ChartMin="0" ChartMax="1" Notes=""/>
That could be interesting to see what conditions cause the acceleration flag to be set related to MAF tuning.
SmurfZilla
Aug 16, 2015 03:50 PM
goforwand
Dec 29, 2013 07:47 PM
