Evo 10 - Ecuflash - 3 tables
Old Jun 8, 2008 | 08:28 PM
  #91
TTP Engineering's Avatar
Keep up the good work guys. Sounds like we made a sound decision to wait on the opensource programming.
Old Jun 9, 2008 | 05:46 AM
  #92
StevenStarke's Avatar
Originally Posted by Evo-L
You guys are awesome. I wish I had the slightest clue as to what you are talking about so I could help.
+10
Old Jun 9, 2008 | 01:46 PM
  #93
Evo_Jay's Avatar
nice
Old Jun 9, 2008 | 01:56 PM
  #94
Evo_Jay's Avatar
Originally Posted by razorlab
Here it is with WGDuty:
Could be right? Although I would think that the table should be BoostBar and X should be load or even TPS since it's a 3D boost table but none of the loads or TPS/voltage work.
Thats super dope its a 3d table, instead of 2d.
Old Jun 9, 2008 | 02:20 PM
  #95
evostang's Avatar
I have a semi-on topic question given the context of this thread. Will it be possible to clone an ECU? Meaning, I buy an ECU for an EvoX, reprogram whatever code is required to make it function in my car, and then swap out my stock unmodified ECU, for the modified ECU?
OR, if there is a flash counter in the EvoX, which has been speculated previously, will it be possible to overwite that checksum?
Old Jun 10, 2008 | 05:19 AM
  #96
hfalex's Avatar
+100!!!!!!!!
Old Jun 10, 2008 | 01:53 PM
  #97
mrfred's Avatar
Originally Posted by jcsbanks
M32176 has only 512K flash ROM though?
Just got word that its a 32196. I should have more details this evening.
Old Jun 10, 2008 | 04:17 PM
  #98
Chabada15's Avatar
why would you want to buy another ecu? your stock ecu is flashable i dont understand the need for you to do that?
Old Jun 10, 2008 | 05:17 PM
  #99
Ph3n1x's Avatar
Its not the ECU, its usually the components that are directly connected that cause limitations. But we are far from that when it comes to the X.
Old Jun 10, 2008 | 07:48 PM
  #100
Ludikraut's Avatar
Originally Posted by MalibuJack
Nice.. I definitely will be getting myself a new CAN/Openport cable, and an ECU and building a bench harness to work at it sometime in the future.
I have to buy a new car some time in the future.. It might end up being an X or Ralliart (the AWD turbo if they release it) so I've been watching this stuff, but not participating much.
Yep, I will be getting a CAN/Openport cable for my Suby. Sorry I can't help with the Evo X stuff. We'll see what happens when the AWD Ralliart comes out, I might end up getting one. IMO an intelligently modded Ralliart is going to kill the Evo X as a DD.
l8r)
Old Jun 11, 2008 | 04:44 PM
  #101
did we hit a brick wall? or are all the tables decoded?
Old Jun 11, 2008 | 05:05 PM
  #102
mrfred's Avatar
To really get at all the tables and understand their purpose, we need to be able to disassemble the ROM. Neither myself nor any of the usual suspects I've talked with have been able to successfully disassemble the ROM. I'm sure it will happen, but getting into the ROM is not quite as easy as I expected.
Old Jun 11, 2008 | 05:12 PM
  #103
cossie1's Avatar
OFF TOPIC here.
mrfred, just wondering how you got on with that rom I sent you the other day ?
Old Jun 11, 2008 | 05:29 PM
  #104
mrfred's Avatar
Originally Posted by cossie1
OFF TOPIC here.
Sorry, hadn't looked at it yet. I'll check on that 2-byte variable this evening.
Old Jun 11, 2008 | 05:33 PM
  #105
cossie1's Avatar
no probs mate, if you get the time, can you see if there is a table to remove the timing limit too (so we can get it to go more than -10°).
And any other tables that might be lurking in there (don't want much do I)
I've had a go with ida pro, and I get lost with it very quickly
