Sponsored by:
Sponsored by: CARiD
Understanding ASC: What it does and reported problems & codes (thread merge)
Old Nov 14, 2008 | 12:09 PM
  #166
TTP Engineering's Avatar
The prototype #2 customer just left here. We'll analyze his map and see if we can find any variances since he has NEVER got the ASC light.
The nicest part of all of this is that every ZChip user is able to login to www.zchip.net and download updates, trade maps, self tune and adjust at their leisure.
Old Nov 14, 2008 | 12:16 PM
  #167
lallen3's Avatar
Are "first batch" Zchip buyers going to get a cable from Zeitronix / TTP?
Old Nov 14, 2008 | 03:00 PM
  #168
Acewolf's Avatar
I have had ASC light come on with the following mods.
- Custom 3" Full Exhaust
- Agency Power Intake
- Agency Power Intake Elbow
- Buschur Intercooler
- Buschur Upper Pipe
Old Nov 15, 2008 | 05:43 AM
  #169
gunzo's Avatar
Originally Posted by lallen3
Quick update after getting a few minutes with an ASC compatible CAN scanner.
ASC:
U1417- Implausible coding data from engine
C121c - Torque reduction request signal rejected
Engine:
P1235 - Mass Aiflow Sensor Plausibility ---Note, I had tweaked boost levels higher before this code set, so it may not pertain to the ASC issue.
There is a Torque / Airflow map on the stock ECU ..
I've already said .. there is alot of communications going on with the engine ECU and the rest of the accessories .. the SES light is probably due to signal mismatch ..
If you wonder why I know .. search for my posts on disassembling the X ECU .. and NO I am not guessing
Also ASC /ABS is part of SAWC ..you remove ASC totally .. you actually revert back to older gen evo SAYC / ACD combo ..
Weather is turning cold .. you guys are going to get alot of this airflow mismatch crap soon especially the MBC owners
Old Nov 15, 2008 | 08:29 AM
  #170
PaRanHaNeul's Avatar
my car did the same during free rev so i just dont free reving anymore but my car never threw code while hard driving. so i am sure its little bug mitsu need to fix or give reflash for the troubled ecus...
Old Nov 15, 2008 | 02:36 PM
  #171
lallen3's Avatar
I set my mbc back to 24, & ses is gone, not worried about that one at all right now. I am aware that abs-asc is part of the s-awc.. Just need to get to the root of the ASC warning for now..
Old Nov 15, 2008 | 03:09 PM
  #172
AWD Motorsports's Avatar
Ive been beating the **** out of my GSR all week w/o any issues.. I cant imagine what is causing that pesky light to come on for you guys with the z-chip..
Old Nov 15, 2008 | 04:55 PM
  #173
Its been addressed that the ECU would like to reduce torque to the wheels, however the ZChip denies it's request to reduce power and torque.
Old Nov 15, 2008 | 06:11 PM
  #174
lallen3's Avatar
I hope addressing the ASC issue is still a priority.
My X is decommissioned for now, though.. Did a single pull from 0-80 & ASC warning popped on, accompanied by a loud noise & massive loss of trans/xfercase fluid, whining noises & a glowing red turbocharger..
Old Nov 15, 2008 | 06:25 PM
  #175
NateDaJew's Avatar
^^^^^^^ You Are Joking^^^^^^^^^
Old Nov 15, 2008 | 06:44 PM
  #176
lallen3's Avatar
Unfortunately, I am not. The X has already been turned over to Mitsu in Dallas for repairs. Estimated to get it back Wed..
Note: It was night, and the turbo was glowing, which *may* be normal, I don't know. TTP may chime in on this one. This is my first turbocharged vehicle.
Old Nov 15, 2008 | 06:53 PM
  #177
NateDaJew's Avatar
That blows. I guess the dealer will ok the warranty being the chip was PNP.
Old Nov 15, 2008 | 06:57 PM
  #178
lallen3's Avatar
It rolled in all-stock
Old Nov 15, 2008 | 07:07 PM
  #179
NateDaJew's Avatar
I guess TTP will want the chip back for testing. Keep us posted.
Old Nov 15, 2008 | 07:13 PM
  #180
Whaaaat??? Are you positive its tranny / Tcase fluid?? What speeds were you at when it failed?? Its very unlikely to damage tcase or tranny once the car is up and running past 60mph.. you sure it didnt window the block?? Im sorry to hear about what happened to the car.. You were one of the few really working on getting the ASC issue resolved.. I cant imagine what failed on an EVO w/ ~320whp...
Mike
