TephraMod V7
Old Nov 18, 2009 | 06:36 PM
  #1066
Wiznaz's Avatar
Thanks! Also, I can't see the value window in the 'NLTS RPM Drop' box. I type "=" and nothing appears either. I hit Alt-G and it crashed the program
Old Nov 18, 2009 | 06:52 PM
  #1067
tephra's Avatar
scaling is probably missing...
what version of ecuflash u using?
Old Nov 18, 2009 | 07:40 PM
  #1068
Wiznaz's Avatar
Latest 1.42
Old Nov 18, 2009 | 07:51 PM
  #1069
D-VO's Avatar
Originally Posted by Wiznaz
Latest 1.42
Right click on the table, click edit. Right now it may show (none) in the scaling box. This should be unit16, and this is a common scaling. Click on the arrow and srcoll down until you see unit16. Click ok...done. I had this problem a couple of times using the 96530706, I think this may have something to do with using an xml with no inheritence.
Old Nov 18, 2009 | 09:05 PM
  #1070
Boosted GP's Avatar
Hey guys,
so is seanv and me the only one with the timing issues? this is a glaring problem in the sense that where is the ecu getting its numbers from?
i can tune around it by looking at the logged timing and getting that to what i want, but still not right.....
if i cant find the issues, i might go back to small maps:-(
Mike
Old Nov 18, 2009 | 09:20 PM
  #1071
TTP Engineering's Avatar
Ours runs perfect.
Old Nov 18, 2009 | 09:30 PM
  #1072
Boosted GP's Avatar
Why?
wonder if we have the wrong formula in evoscan, but then it would be out at idle too.
Tephra? your thoughts are desperately needed.
Mike
Old Nov 19, 2009 | 04:04 AM
  #1073
SeanV's Avatar
Originally Posted by Boosted GP
Why?
Mike
Here is a log/map trace of the same problem I am seeing.
Log was done in 3rd gear and 100% throttle started at load site 90, 2000 rpm all the way to 7000 rpm.
And a pic of the full iginition tables as the big maps doesn't show up fully in the map tracer.
Old Nov 19, 2009 | 10:29 AM
  #1074
GST Motorsports's Avatar
Which load are you logging?
- Bryan
Old Nov 19, 2009 | 11:06 AM
  #1075
SeanV's Avatar
- Bryan
2Byte....
Edit: Arrrgghhhh, let me guess, the problem is due to me using 2Byte load, when I should be using 1Byte Load.
Old Nov 19, 2009 | 11:39 AM
  #1076
Mellon Racing's Avatar
the difference between the two shouldn't be that significant
Old Nov 19, 2009 | 12:34 PM
  #1077
donour's Avatar
It is under boost for me. They track each other to about 100 load, but above that 1byte load can be 15-20% higher than the baro+temp compensated value.
d
Old Nov 19, 2009 | 02:05 PM
  #1078
even good ole "load calculated" wasn't off that much
Old Nov 19, 2009 | 02:35 PM
  #1079
nonschlont's Avatar
From what Ive seen, 2ByteLoad follows 1ByteLoad, "almost identically" but if your using 2byte (temp + baro), then there will be ~ 10 - 20% difference between 1byte and 2byte temp + baro.
Old Nov 19, 2009 | 03:53 PM
  #1080
donour's Avatar
Why would you _not_ log temp+baro corrected load? It was my understanding that the corrected value is usually used for table lookups (in 96530006 at least). LOAD_RAW is quite a lot higher underboost -- several cells off.
d
