Bilstein HDs are IN! Swift and GTWORX Bilstein kits. And coilovers. And pics of Carol
FINALLY!
These shocks come in and out of stock, always hard to find. But always an awesome choice. Basically these dampers were tested by a few track and auto-x guys that actually drive their car on the street and were found to be a much better all around solution than the cheap coilovers in the same price range.
Then Bilstein barely made a handful at a time, and a small number of lucky individuals have been able to get their hands on them.
Well we went ahead and did our own separate order from Bilstein and have a bunch of them IN STOCK ready to ship!
Oh and say hello to our Carol, our new marketing and logistics manager.
We're offering them with our GTWORX springs and Swift springs, the only springs worth considering for your EVO. Both are excellent choices with excellent spring rates for the track, while still maintaining good ride quality and driveability on the street. The Swifts are a little lower in ride height, and the GTWORX springs are between the two Swifts in stiffness. Bottom line, people are winning events and beating the lower priced coilovers while enjoying better durability and driveability with both brands.
Bilstein + GTWORX
https://www.evolutionm.net/forums/se...ine-cusco.html
https://www.evolutionm.net/forums/8274966-post26.html
The Bilstein GTWORX kit
Bilstein HD
GTWORX Springs
$1119
Bilstein + Swift
https://www.evolutionm.net/forums/ev...-reviewed.html
The SmikeEvo Bilstein Swift kit
Bilstein HD
Swift Sport Springs
$1179
The SmikeEvo Bilstein Swift Spec-R kit
Bilstein HD
Swift Spec R Springs
$1199
$849 on their own.
CALL now to order!
I'm liking these advertisement methods
I'll be checking your threads more often
Everything in the picture is included when I order right!?
In case you hadn't heard, Ohlins DFV Coilovers are back!
These were improved over the older version with better valving and better build quality.
8k/10k spring rates
Includes front camber plates and rear pillowball mounts
dual height adjustable
Rebound adjustable with improved Dual Flow Valve technology for awesome handling and ride quality.
We've worked with a member to develop a great set-up guide for Ohlins and can help you dial in ride height, alignment, and damper settings for the street and track.
SALE price of
$3149
8k/10k spring rates
SALE price of
$3149
Finally a new coilover option at a realistic price, that doesn't suck! Awesome euro valving, tons of suspension travel, great USA support, great build quality, and a proven track record (used on the 2009 Redline Time Attack Street champion car).
Monotube, single damping adjustable, with Swift OR Hyperco coilover springs depending on stock.
All sets can be CUSTOMIZED....we can work with you on a desired spring rate to match your car and driving style.
CALL OR PM
This price includes custom spring rates and helper springs at all 4 corners.
Avoid the too much rebound, not enough compression damping, poor quality springs, clueless tech support, non-existent suspension travel, coilovers that are so widespread out there....and get something that WORKS!
CALL OR PM
GTWorx/RCE EVO Springs
$279 Shipped
Call 410-579-1501
I believe these are the best handling track springs for the Evo 8/9 on the market. These are not poser lowering "show" springs. These are handling springs that maintain good ride quality and a pretty good look.
Here are the specs:
Ride Height
20mm Drop Front
20mm Drop Front
15mm Drop Rear
Spring Rate
290 lbs/in Front
330 lbs/in Rear
Reviews:
Pics:
Whiteline Geometry and Bushing Package - $449!
Whiteline Roll Center Kit
Whiteline Bumpsteer Correction Kit
Whiteline Rear Trailing Arm Bushings
Whiteline Front Control Arm Bushings
These Whiteline Geometry and Bushing parts correct the adverse effects of lowering an EVO while removing a lot of the "slop" from the stock bushings. Firmer bushings prevent dynamic changes in camber, caster, and toe, while the Roll Center Kit relocates the roll center of the car, correcting a side effect of lowering an EVO.
These parts make a great addition to GTWorx Suspension Stages or any coilover system.
Oh my - Were there any suspension parts in those pictures?
That bilstein spec R combo is tempting.
Curious what this combo compares to stock combo - weight wise? Hoping for some reduction in weight...
