New 3D VE Maps SD Rom
Strange... FWIW I have the same issue. I DL the 9653 zipped xml and it says either compression corrupted, no file or invalid file when I try to unpack it. I'm presently on an XP Dell mini10.
I''ll see what else I can try...
Thanks for the effort
Do I need to scale for my JDM 3 bar? It looks like the original 2D tables in your ROM are set up for the Omni 4 bar.
Is this where I would change the MAP scaling (old tables) and the 3D table will update?
Everything else looks pretty clear. Thanks for doing 9653... I have this ROM noodled to perfection, I was willing to go back to 9715 but this is much easier. If I get the basics roughed in like injector scale and latencies tonight I'll try to flash it to the car tomorrow and see what happens.
Thanks.
Thanks.
Thanks.
Thanks.
The 3d table (the VE one) isn't really scaled to any map sensor its just a percentage thing so i'm not sure what your implying.
Yeah you will need to rescale I think phenom sets them to the omni 4 bar by default. Once the scalings set you should be able to just copy over your tables from the old rom.
Ok got it on the MAP scale thanks. I guess what I'm still not understanding is if you copy the 2D tables, MAP/Kpa and RPM/VE over into the new ROM how is the 3D table generated and what are the values currently in it? Do I need to calculate those from the data in my current tables?
I noticed that in the "Speed Density Programming 3d VE" that the addressing looks incomplete. I have attached a screen shot to show this. If everything is good to go then I will transfer all of my setting over and try this out.
Roadspike,
Is this a combination of both the MAPVE and RPM VE table or just a 3D RPMVE table (basically)?
The reason I ask is the MAPVE table is a quick global adjustment and is handy for part changes retunign, where a 3D RPMVE table is very helpful for driving and fine tuning but would be slower to setup if it were the only table.
This might only affect me since I dont use a 1:1 ratio in the MAPVE table generally. If the Load point adjusts off a preset, then altering that would alter the ratio I suppose. Nice work though sir, looks very similar to the DSMlink V3 table.
aaron
aaron
