New 3D VE Maps SD Rom
Old Jan 31, 2011 | 10:35 AM
  #61
RoadSpike's Avatar
Originally Posted by 3gEclipseTurbo
So I add all the xml to the current 94171715 SD tephra xml or replace it?
I'd just replace it
Old Jan 31, 2011 | 10:39 AM
  #62
3gEclipseTurbo's Avatar
I just replaced it, the 3D table is 199 for the entire inside of the map
Old Jan 31, 2011 | 10:44 AM
  #63
RoadSpike's Avatar
Did you open up the rom that i patched or just one of yours?
Old Jan 31, 2011 | 10:47 AM
  #64
My current 94171715 SD rom, download yours and copy over the 3D table??
Old Jan 31, 2011 | 10:48 AM
  #65
RoadSpike's Avatar
I don't have to explain why then right?
Goto post one and download the rom i posted.
Old Jan 31, 2011 | 10:52 AM
  #66
I got in the ninja edit lol
Old Jan 31, 2011 | 10:53 AM
  #67
RoadSpike's Avatar
No just use the prepatched rom copying the table wont do anything with the right code behind it.
Old Jan 31, 2011 | 11:13 AM
  #68
Alright, does the old 2D table still have any effect?
Old Jan 31, 2011 | 11:16 AM
  #69
RoadSpike's Avatar
Map sensor one does RPM does not.
Old Jan 31, 2011 | 11:19 AM
  #70
Ya thats what I meant
Old Jan 31, 2011 | 11:39 AM
  #71
Ill let you know the results, wont be able to do any driving with all this snow were getting but idle and free reving. This is where I hope to see the biggest improvemnet, free rev was horrible it would bounce between extremely rich to extremely lean.
Old Jan 31, 2011 | 11:54 AM
  #72
And's Avatar
And
are there any plans to add this to the DMA rom?
i'll be trying this asap 9653 once I've copied over all my settings
Old Jan 31, 2011 | 11:58 AM
  #73
RoadSpike's Avatar
It should be no problem to patch this into a DMA prepatched rom however I have no idea how to patch the DMA code into a rom, i could probably figure it out but I'd rather not .
First I want to see if this really simple way of doing things will work out. I have the fear the load will drift a bit since the table uses compensated load and if i have to i'll extend the axis table to use an uncompensated load.
Old Jan 31, 2011 | 12:20 PM
  #74
So its not gonna fallow the same load Im logging in evoscan with the v7 data in evoscan?
Old Jan 31, 2011 | 01:15 PM
  #75
RoadSpike's Avatar
It is but I'm not sure if it will run perfectly like that which is why i need its tested.
