New 3D VE Maps SD Rom
Old Jan 31, 2011 | 12:19 AM
  #46
RoadSpike's Avatar
Originally Posted by JohnBradley
Roadspike,
Is this a combination of both the MAPVE and RPM VE table or just a 3D RPMVE table (basically)?
The reason I ask is the MAPVE table is a quick global adjustment and is handy for part changes retunign, where a 3D RPMVE table is very helpful for driving and fine tuning but would be slower to setup if it were the only table.
This might only affect me since I dont use a 1:1 ratio in the MAPVE table generally. If the Load point adjusts off a preset, then altering that would alter the ratio I suppose. Nice work though sir, looks very similar to the DSMlink V3 table.
aaron
Its a 3d RPM VE table basically I'm using compensated load and rpm to produce a VE value the old table is still there just for reference to you guys
I may have to make my own uncompensated load axis for the table if this simple workup doesn't suffice.
Old Jan 31, 2011 | 12:21 AM
  #47
RoadSpike's Avatar
Originally Posted by 95630706
Ok got it on the MAP scale thanks. I guess what I'm still not understanding is if you copy the 2D tables, MAP/Kpa and RPM/VE over into the new ROM how is the 3D table generated and what are the values currently in it? Do I need to calculate those from the data in my current tables?
The 3d table isn't generated its just values I setup in it to get your guys started.
The old 2d table isn't used but is shown for reference.
I'd say just start and go you should be able to see if the rom works first lol which is the goal here guys :P
Old Jan 31, 2011 | 12:24 AM
  #48
RoadSpike's Avatar
Originally Posted by drifterific
I noticed that in the "Speed Density Programming 3d VE" that the addressing looks incomplete. I have attached a screen shot to show this. If everything is good to go then I will transfer all of my setting over and try this out.
I'm really confused by your statement "looks imcomplete" do you mean the FF's at the end of it? Those are there because the table isn't as large as shown in that programming section.
The v7 table btw was a fuel table which i copied into the "new ve" table to get started I wouldn't just copy that over. Also are you trying to program the rom from a current one you have? If you did you just overrode one of your fuel tables, can't rememeber which one it was.
Old Jan 31, 2011 | 09:39 AM
  #49
3gEclipseTurbo's Avatar
I got 7zip to extract it but when I open it its not in readable writing
Old Jan 31, 2011 | 09:47 AM
  #50
4xforce's Avatar
Hey Roadspike. Great stuff here. 99% of which is totally foreign to me but if you need a car to test this out on just let me know.
Old Jan 31, 2011 | 10:02 AM
  #51
92LaserRs's Avatar
This is so awesome! Cant wait to start playing with it.
Old Jan 31, 2011 | 10:15 AM
  #52
RoadSpike's Avatar
Even the one that i posted later?
Man i don't know what to say something is up with that computer bro.
Old Jan 31, 2011 | 10:16 AM
  #53
Its 2 weeks old HP G42
Old Jan 31, 2011 | 10:18 AM
  #54
RoadSpike's Avatar
Both of these where compressed with the windows 7 built in compression tool if they don't work i don't think i can help ya.
https://www.evolutionm.net/forums/9034219-post36.html
Old Jan 31, 2011 | 10:21 AM
  #55
I got it, ****s weird I had to extract it twice???
Old Jan 31, 2011 | 10:23 AM
  #56
RoadSpike's Avatar
I think something is up with your computer bro no reason you need to extract twice.
You don't have one of those crappy internet "speed up" programs do you? Like netzero used to do.
Old Jan 31, 2011 | 10:27 AM
  #57
comcast
Old Jan 31, 2011 | 10:29 AM
  #58
I see what happened, the first time it extracted it it was a file then the second time it extracted the file to a xml. Idk Im not a computer wiz by any means.
Old Jan 31, 2011 | 10:31 AM
  #59
RoadSpike's Avatar
Sounds like your computer is compressing all internet traffic thus the double extract. when i download those files here at work they only extract once.
Old Jan 31, 2011 | 10:34 AM
  #60
So I add all the xml to the current 94171715 SD tephra xml or replace it?
