New 3D VE Maps SD Rom
New Roms
88591715 Standard 3D Patch:
http://www.megaupload.com/?d=T00SQMOI
88591715 New Map VE Axis Patch:
http://www.megaupload.com/?d=F1VCCYNX
9417 New Load Axis Patch:
http://www.megaupload.com/?d=Y52RISA6
9653:
Not doing this just yet maybe tomorrow if i can't get testers.
Please ignore the various misc tables I'm adding we can clean up the xml, finalize it, when we can confirm it actually works.
The New load axis will use the map VE Load generated off of the Map Sensor VE table. Using this load should be independent of the map sensor voltage so no worries on that front.
9653:
Finished up the 9653 variant with different load axis.
Now that all three are done i'm positive we should get some results on which method works the best.
9653 New Load Axis:
http://www.megaupload.com/?d=TJ8RM8V9
9653 New Load Axis:
