AEM EMS Get tuning help for your AEM EMS system.
During Shifts...
Old Feb 23, 2007 | 05:14 AM
UndieStainz's Avatar
During Shifts...
I wondered if you guys had this happen. Between shifts, and I mean 1st gear engaged,...off the gas - clutch and then 2nd gear, it seems as though the engine keeps revving as if the throttle cable is stuck.
Could this be related to any setting within the EMS or could it really be a stuck throttle cable? It only does this in the first 3 gears or so or when up to speed 60+.
Old Feb 26, 2007 | 03:39 AM
Could this happen because of the decel settings on that table? rpm/boost related? ...anybody?
Old Feb 27, 2007 | 07:47 AM
jbrown's Avatar
accel and decel fuel are two of my weak points on the AEM, sorry I can't help. Here's a bump at least.
edit: on second thought, try playing with your high idle settings. they keep the car from stalling and may be set too aggressively.
Old Feb 28, 2007 | 06:23 AM
GTVEVO's Avatar
Off the top of my head it sounds like the idle feedback is set too high along with the feedback value probably being off a little bit. You shouldn't need idle feedback above 1300-1500 rpms so this is somthing to check out. Also be sure the idle feedback table is tuned accurately across the entire rpm range.
Old Feb 28, 2007 | 06:43 AM
GT..'preciate it bro...
Old Mar 12, 2007 | 08:47 PM
alpha's Avatar
Idle Feedback or Hi Idle RPM Offset and High Idle Wait Time are too high
Old Mar 14, 2007 | 05:32 PM
alpha. great info, here my current settings:
1. High Idle RPM Offset 150rpm
2. High Idle Wait Time 2.00 sec.
3. Idle FB above RPM 400
4. Idle FB below RPM 2500
Whatcha guys think? Should I lower the wait time and drop FB to 1500 or so?
Old Mar 15, 2007 | 04:24 PM
alpha's Avatar
I have no idea about your setup but try the following ...
Hi Idle Car Speed 7
High Idle Wait Time 1.50
Idle FB Above rpm 400
Idle FB Below rpm 1800
Also. Change your Fuel Off Above RPM to 1800. This also depends on your low rpm low load fuel map as well. If it isnt smooth it isnt going to work as good. Good luck
LaurenBBY
33
Aug 30, 2016 09:48 AM
smoOVE
Feb 17, 2013 06:49 AM
williamgasdick
10
Oct 23, 2011 09:29 AM
Ralliartize It
Aug 29, 2011 03:06 AM
EVOMIZ
Jan 27, 2011 12:57 PM
