AEM EMS Get tuning help for your AEM EMS system.
AIT sensor location
Old Sep 6, 2007 | 08:16 AM
frycztech's Avatar
AIT sensor location
I wanted to know where i should install the AIT before the meth. jet or after(the ait closer to the throttle body and the meth further). how close should they be to each other?
Old Sep 6, 2007 | 10:46 AM
PPI's Avatar
PPI
It shuld be installed upstream of your meth nozzle.
Old Sep 6, 2007 | 12:33 PM
milo's Avatar
Properly position for AIT should be in the intake manifold but for easy of install most peeps just install them onto the intercooler pipe(Intercooler to TB)
Old Sep 6, 2007 | 01:03 PM
EVOLex's Avatar
Install it before the throttlebody.
Old Sep 6, 2007 | 01:31 PM
steelcityevo8's Avatar
bump on this subject as I am going to install meth soon and need to know if the meth nozzle should be installed before the IAT , so that it will see the cooling benifits of the meth. or opposite IAT first then meth nozzle.
How far away from the throttle body is too far for the meth nozzle?
Old Sep 6, 2007 | 05:16 PM
frycztech's Avatar
I know they both go in the intercooler pipe to the throttle body i just want to know what order and if there is any spacing needed.
Old Sep 9, 2007 | 06:07 AM
frycztech's Avatar
bump
Old Sep 11, 2007 | 11:03 AM
DynoDude55's Avatar
Your IAT sensor needs to be mounted as close to your throttle body as possible however, your meth nozzle needs to be inbetween your IAT sensor and the throttle body.
If you mount the meth nozzle before the IAT sensor it will throw off the temp readings and cause problems.
Old Sep 12, 2007 | 11:57 PM
EvoKnievo's Avatar
^ +1 thats what i thought, does anyone think we should weld that bung onto my intake manifold?
Old Sep 17, 2007 | 06:22 AM
frycztech's Avatar
so it should be from top to bottom
throttle body
meth nozzel
and then my aem ait sensor
bov
is that right?
Old Sep 18, 2007 | 09:56 AM
frycztech's Avatar
Is that order right ?
Old Sep 18, 2007 | 12:52 PM
DynoDude55's Avatar
Yea, that should work fine.
Old Oct 11, 2007 | 01:09 AM
EvoKnievo's Avatar
what about putting the AIT sensonsor through a series of adapters so i can threadt it into the manifold like my map sensor?
Old Nov 17, 2007 | 06:46 AM
dubbleugly01's Avatar
this will work fine if you're not spraying meth. Just make sure your adapters aren't too long such that the sensing portion of the sensor is not in the airflow.
asu11
May 10, 2012 10:27 AM
EvoTornado
Jun 26, 2010 04:25 PM
1FastOZ
Lancer Engine Tech
21
Jul 22, 2008 11:32 PM
binh
10
Aug 15, 2007 08:47 AM
QuickEvo
AEM EMS
19
Nov 16, 2005 09:21 AM
