AEM EMS Get tuning help for your AEM EMS system.
Bad EMS unit?
Old Mar 28, 2010 | 09:28 AM
mugen777's Avatar
Bad EMS unit?
Alright guys well finally got my car finished up now it wont start... I can not for the life of me get any computer to connect to the ems and the car will not start.
It will turn over but the fuel pump won't kick in, when a battery source is hooked to the fuel pump boom it kicks on, also there is no spark.
We have replaced cam angle sensor, crank angle sensor, checked all relays for the pump and still nothing.
Seems like the ems is just shot? Im really out of ideas
Any ideas or thoughts??
Thanks alot guys!!
EDIT: Also when trying to connect it just says frame error, parity error, break error and it will never connect. I never had these issues before...
Old Mar 28, 2010 | 08:46 PM
Mark14's Avatar
I'll call them tomorow about the ECU
Old Mar 29, 2010 | 10:56 AM
project_skyline's Avatar
You need to send your ECU in. It sounds like a bad Eprom chip.
Mine had the same problem.
Old Mar 29, 2010 | 11:08 AM
mugen777's Avatar
How much was the repair? Also any idea what caused it?
Old Apr 11, 2010 | 08:28 PM
Mark14's Avatar
Yea it's a bad unit since some Honda techs were under the hood and shorted some things out.....lol
Old May 16, 2010 | 11:02 AM
SkipDMan's Avatar
You need to check if you are getting 'Stat synced'. If it is 'on' and you have no spark/fuel, reload your firmware and try again. If that doesn't fix it, call AEM for an RMA and send it back.
If 'stat synced' stays 'off' during cranking then check the parameter 'timing error'. If the errors continuously increase while cranking you have a mechanical timing or sensor issue. If it stays off and you do not get timing errors then it is not receiving your crank/cam sensor signal at all.
Old May 16, 2010 | 12:05 PM
griceiv's Avatar
try disconnecting/reconnecting your battery first before you send it back.
Old May 19, 2010 | 05:18 PM
dcamp56's Avatar
did you try returning it? i never heard of this?
xceler8rob
34
Jul 17, 2016 12:57 PM
Auger
May 4, 2015 09:19 PM
203FPEVO
Mar 15, 2010 09:42 AM
nutrulz
AEM EMS
Aug 18, 2008 01:49 AM
LIFER
AEM EMS
26
Apr 4, 2006 12:05 PM
