AEM EMS Get tuning help for your AEM EMS system.
revving pass rev limit
Old Nov 4, 2011 | 12:21 AM
iziegsx's Avatar
Hey all,
I have an aem ems v1 in my car and even with the rev limit set to 7800 it still revs to 9k. Fuel cut is set to 8k. Any assistance will be greatly appreciated! Thanks!
Old Nov 4, 2011 | 08:30 AM
TheBoz's Avatar
Setup->Rev Limeters->Main Rev Limiter->Main Rev Limiter Wizard-> Select Level 10.
This might be your Rev Limit Cut Level. I have seen the base maps with Level 1 set and that would allow you to just continue reving as high as you want. Once I changed mine to level 10 it solved my problems. Now if you are running NLTS you can still overshoot your Main Rev Limit, you will need to search the AEM Forums for full details, not going to re type it all.
Old Nov 6, 2011 | 10:07 AM
Aby@MIL.SPEC's Avatar
just know that any type of rev limiter, be it 2 step or NLS limiters CAN all over-ride the main rev limiter.
if you activate a certain rev limiter, then that is the rev limiter.
there is no safety net.
if you dont beleive me, set your main rev limiter to 2k revs, then set your launch / 2 step to 3k & note where your engine revs too
03OZstocker
Lancer Engine Management / Tuning Forums
Mar 30, 2017 10:27 PM
black_beauty
Mar 14, 2014 04:25 PM
dragon831
Nov 12, 2012 08:02 AM
Jamessvt2004
AEM EMS
26
Jul 5, 2012 10:12 PM
Oracle1
Mar 25, 2011 03:40 PM
