Turbo or engine swap?
Old Jan 6, 2004 | 07:00 PM
j3bu5's Avatar
After looking into both of these options i still cant decide what to do.... the choices are a turbo kit from rpw or a 6A12 mivec (replaceing the 4G15 in my 99 GLi lancer). The mivec will give me more power, but a whole engine replacement can be rather costly and there is i higher risk that something will go wrong.... the turbo kit dosent give as much power but is cheaper and less dangerous then a whole engine replacment. So what would u guys do/recomend?? does the power increase realy justify that much money? or should i just save it and buy a better car ?
thanks for your input
Old Jan 7, 2004 | 05:15 PM
RalliArt1994's Avatar
its really up 2 you, since its a lancer why not put in a 4g92g mivec
its not hard to fit, and its bang 4 buck
Old Jan 7, 2004 | 08:40 PM
rexhunta's Avatar
I'd go engine swap.. the turbos do have more problems then engine transplants.. you gotta bit to do when you putta turbo on, and sometimes, cheaper to swap.. but they bout the same..
Old Jan 8, 2004 | 05:27 PM
j3bu5's Avatar
i have never heard of a 4g92g mivec, what car is it from and are u sure it fits? and what are the differences between it and the 4g92 (besides the mivec or does the G mean its mivec??)? Any1 seen this conversion done? thanks again
Old Jan 9, 2004 | 01:27 AM
Leppy's Avatar
I wouldn't go the engine swap... the amount of extra chassis strengthening that you'll need to make it handle right again... The 6A12 is a heavy engine compared to the 4G93... Your lancer is gonna plough like a ***** with this engine swap....
Old Jan 9, 2004 | 01:30 AM
Mivec's Avatar
The 4G92 DOHC 1.6L Mivec is a good little engine in a Mirage, anything bigger than that and it is not exactly going to be that good. It does have a power output of around 130kw but you have to rev the guts out of it to get anything at all. The torque is terrible and to be honist I can not see the value in getting one in a CE Lancer. The CE series are far more expensive and rarer than the CC series engines. Unfortunately the 4G15 SOHC 1.5L engine is never going to perform well either without a truck load of money spent on it. If I were in your situation I would enjoy the car as is for a little bit, do a few modifications if you like then upgrade to another car which either has the power there to start with or can be easily modified.
Old Jan 9, 2004 | 01:38 AM
Leppy's Avatar
Yeah I agree with mivec... Although a a bored and stoked 4G93 would do well...
Old Jan 9, 2004 | 01:39 AM
Drive02Lancer's Avatar
well i dunno about the 99, but for the newer lancers, RPW i think said the 6a13 or the galant vr4 engine almost bolts up and is no prob....so thats a 6 cylinder turbocharged engine in the '4banger' lancer...imagine that!!
Old Jan 9, 2004 | 01:44 AM
Leppy's Avatar
Thats gonna be only good for a drag car with huge amounts of torque steer.....
It does fit but its super tight... make sure you don't want your legs if you run into something...
Old Jan 12, 2004 | 03:04 PM
j3bu5's Avatar
found some half cuts.....
MIVEC 4G92 RH mount suit CE plus Lancer/Mirage. Triptronic auto (RH mount) $4200
MIVEC 4G92 suit CE/CJ Lancer, Mirage with 5sp manual (RH mount) $4200
6A12 Mivec 2L V6 with auto FTO suit RH mount. $3850
4G63 TURBO GALANT VR4 72192kms $3000
Galant VR4 4G63 Turbo 4WD manual 116046kms $2800
Old Jan 12, 2004 | 05:11 PM
j3bu5's Avatar
that engine is unfortunatly a AWD, so i would have to get it converted.... and thats even more expensive think i might end up doing as suggested and sell my lancer in 2 years or so and buy a GTO or something....
Old Jan 12, 2004 | 05:58 PM
Mivec's Avatar
If you get a chance can you send me an email graemekhughes@hotmail.com
We can talk a little more about what can work there.
Old Jan 12, 2004 | 09:36 PM
j3bu5's Avatar
email sent mivec
fireroasted
18
Nov 2, 2015 06:37 AM
JaMRxHanzoxOZ
Lancer Engine Tech
May 26, 2014 11:16 PM
ottoman
Aug 22, 2011 05:18 AM
KooIDud3
Jan 27, 2008 06:11 PM
dan l
Jun 3, 2007 07:06 PM
