Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
Twin-scrool vs. Open scroll test!
Old Aug 29, 2007 | 07:00 AM
  #31
AMS's Avatar
AMS
Originally Posted by evodan2004
also this test dose not say it used a twinscroll manifold. twin waste gates. so this test really means nothing in a real twin scroll vs reg setup.
changing just the hotsides was only a waste of the guy who did the swaps time. come on ams you should know better then that.
Hmmm.... let's go back and read the first post.
Manifold: divided & setup up for twin scroll setup
The header was built for a twin scroll setup. After it was built Tim decided to experiment with turbo hot sides.
Old Aug 29, 2007 | 07:02 AM
  #32
Frank@AMS's Avatar
In the first post:
"Custom header with dived runners (for twin scroll)"
Old Aug 29, 2007 | 07:04 AM
  #33
AMS's Avatar
AMS
If someone wants to send me a twin scroll 35R kit I will do a no bull-shi* back to back test and even make a video. I'll do it on my car with nothing else changing but the turbo kit.
I do think a twin scroll would spool a little bit faster (maybe 100-200 rpms?) but it will give up power up top. Even in slow & tight type of road racing I've seen no issues with spool up using 2.0L 30R, or a 2.3L 35R... power comes on quickly, enough to overpower traction if you want it to.
Old Aug 29, 2007 | 07:28 AM
  #34
Ted B's Avatar
I can't comment on the particulars of this test because I wasn't there and I don't know all the variables. What I can say however is the .85 A/R (TS) housing is not the one I would have selected if peak power was the goal.
I can comment thoroughly however on two first-hand experiences I have with open vs TS. In my observations in both cases with actually driving the two different setups, there is absolutely no comparison in the response and feel between the two different configurations. The open setup feels dead until it (finally) comes on boost. The TS setup is far more linear - feels very willing and torquey before the turbo hits. There are things a dyno (especially an inertia dyno) just can't reveal, but are readily apparent from the driver's seat.
Old Aug 29, 2007 | 09:35 AM
  #35
94AWDcoupe's Avatar
100% agreed.
simply changing a/r can make 30hp. single to single scroll
Old Aug 29, 2007 | 09:37 AM
  #36
High_PSI's Avatar
Gettin' hot in here. Has flame suit on and pop corn ready. Anybody have some of the Butter-Flavered topping?
Old Aug 29, 2007 | 10:00 AM
  #37
scorke's Avatar
It's not going to happen.
When smart people discuss new topics the results is usually good.
Scorke
Old Aug 29, 2007 | 10:46 AM
  #38
Ivan@AMS's Avatar
Originally Posted by 94AWDcoupe
100% agreed.
While this can be true, it will make that power at the sacrifice of SPOOL. Check the dyno chart and you will see that the TS and the OS spooled nearly identically.
Had we changed to an OS AR that made the same peak power as the TS (read: smaller more restrictive AR for better spool), you would have seen much more power under the curve than the TS.
Old Aug 29, 2007 | 11:11 AM
  #39
Ted B's Avatar
It's funny how both of my setups also showed roughly the same thing when looking at the spool curve on a dyno chart. However . . .
When the cars were put on the street, the difference in off-boost torque and transient response was night and day. In fact, the difference is so vivid that I can't see ever going back to an open housing. It's a rather stark example of the fact that dynos cannot reveal much beyond what happens at 100% throttle with a static load, neither of which are representative of real world conditions and use.
Old Aug 29, 2007 | 11:17 AM
  #40
homemade wrx's Avatar
and this is why I keep asking for the dynograph to be shown in time as the x-axis and not rpm...see the response time of the turbo as that is the stronghold for a twin scroll. We would need to see a non-interial load dyno graph (not sure which dyno AMS has) or datalogs to see which spools faster in the real world too.
-Micah
Old Aug 29, 2007 | 11:19 AM
  #41
yes, that is true in relation to rpm but I think that Ted B and I are saying in the real world, with real load that the twinscroll takes less actaul time to spool up in comparison to the single scroll.
sorry being a bit too much of an engineer but just trying to see all aspects of the test
-Micah
Old Aug 29, 2007 | 12:49 PM
  #42
2003lancerevo8's Avatar
Well
like Martin said, let's see the no bullshi% test! Someone send AMS a 35Kit and let's see the results.
Steve
Old Aug 29, 2007 | 01:11 PM
  #43
DJ Brett B's Avatar
Hmmm..... I keep reading too much conflicting info in this thread. Everything I have read about a TS setup shows that it decreases turbo lag... ideal for 35R and larger turbos (except maybe for drag racing IF its true it wont make the same top-end power)... so what the dyno suggests and what some people here are saying is that theres no difference in spool up??? WTF? Does that mean that the companies producing TS kits are trying to hoax us??? That doesnt make sense.... Perhaps somebody (i.e. FULLRACE) can post a dyno comparing their old GT35 kit to their new TS GT35 kit, given the same mods/tune/same damn car in every way minus the TS setup....
Old Aug 29, 2007 | 02:54 PM
  #44
EvoDan2004's Avatar
Originally Posted by Frank@AMS
Im pretty sure we spool just about the same or a little sooner on our open scroll 30R kits on a 2.0 in 4th gear.
when i was talking to ams a while back about a turbo setup. i wanted a 30r. they said 20psi at 4400 rpm. in whatever gear i dont know.
i see 24psi in 3rd gear at 3900 rpm..... i actualy spike 25 but hold 24. so take it for whatever way you want too.... i even found some dyno graphs of your 30r setup. and the 4400rpm you guys said you see showed to be true. the guy whos graph it was said his was 3rd gear also.
scorke. lol bro. i was joking. his post was way off. i was just being a smart guy. heheeh
Old Aug 29, 2007 | 02:55 PM
  #45
EvoDan2004's Avatar
Originally Posted by AMS
what gear/load conditions?
3rd gear. load ????? aaaaaaaaa flat ground i guess. lol. what do you mean
