Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
Twin-scrool vs. Open scroll test!
Old Aug 29, 2007 | 06:08 PM
  #61
Ivan@AMS's Avatar
Originally Posted by homemade wrx
I would have to agree with te B in his arguments and questioning...seems 9sec240 is only ever focuses on flat foot, already spooled, drag racing type powerbands; which is not what a TS is designed to benefit. It is designed to benefit turbo response in time (not RPM) as pointed out by Ted B and 9sec 240 in the diesel comparison.
A TS is a great design for people auto-xing and tracking (road course) their cars...it is what I look for as I've been spoiled tracking/auto-xing Formula SAE cars.
I really would like to see a more scientific test done...make it more like a lab report... show various graph's: both power in relation to time and rpm...also pressure in relation to time and rpm. These would show that a TS either does or doesn't truly benefit over a smaller a/r SS turbo and would show what is the better product.
Of course then there are variables that can't be identical such a exhaust manifold, but that is part of the trade off of TS vs SS and what you can get.
You keep insisting that I only care about "drag racing type powerbands". This is FAR from the case. From the very beginning of my involvement in the discussions on TS v OS, my point has been this.
HOW MUCH TIME DO YOU SPEND ACCELERATING WHILE THE TURBO IS SPOOLING VERSUS ACCELERATING ONCE THE TURBO IS SPOOLED???????????????? Keep in mind we are talking about ACCELERATING and not putzing through traffic.
If the benefit of the TS is better spool and you are spooling 10% of the time and at full boost 90% of the time, doesnt it make WAY MORE SENSE to improve the power once on boost versus trying to get the turbo to spool quicker????????????
This doesnt just benefit the drag racer, it benefits the road racer and the every day street warriors. There are SOOOOOOOoooo few instances where I could possibly see any need to be at 3000 rpms at WOT trying to accelerate hard.
If somebody here really needs to be able to accelerate hard at 3000 rpms, then they need to sell their low displacement turbo car and buy a Viper.
Old Aug 29, 2007 | 06:13 PM
  #62
Ivan@AMS's Avatar
Originally Posted by Ted B
Is it really?
Don't both applications aim to spool a relatively large turbo using a relatively small air mass, with relatively long intervals between exhaust pulses? Whether it's a high displacement, low rpm engine trying to spool a turbo, or a small displacement, high rpm engine trying to spool a large turbo, the principle is the same.
The real question is (as far as I am concerned) not if it works (it definitely does), but as the turbine housing A/R increases, if the benefit of the TS design persist beyond the point where the TS housing equals the power of the open housing. FWIW, I've seen more testing to this point indicates that it does than not.
If you are shooting for better spool up, then yes, there are similarities. But the APPLICATION is NOT the same. We are NOT trying to tow anything or haul heavy loads. We are trying to ACCELERATE as quick as possible. This requires high RPM TQ where spool is not a factor.
Old Aug 29, 2007 | 06:19 PM
  #63
EvoDan2004's Avatar
well im on stock block. reving to 7800rpm. a twin scroll 30r IMO is best. fast spool and makes just as much uptop because im not really pushing the turbo that hard.
Old Aug 29, 2007 | 06:31 PM
  #64
Ivan@AMS's Avatar
"just as much" what? "uptop" compared to what?
Old Aug 29, 2007 | 06:35 PM
  #65
EvoDan2004's Avatar
oops. a regular 30r.
like how can i say this. im not pushing the t/s 30r hard enough to have a power loss over a regular 30r uptop. but im gaining in spoolup.... copy??
Old Aug 29, 2007 | 06:42 PM
  #66
Ivan@AMS's Avatar
And you know this how? Anything done on the exhaust side to increase spool will hamper HP up top regardless of turbo size.
Old Aug 29, 2007 | 06:56 PM
  #67
LilRico's Avatar
Would changing from a TS to OS setup, would the car need to be re-tuned even if the same turbo with the same exact A/R were used?
Old Aug 29, 2007 | 08:11 PM
  #68
trinydex's Avatar
I know you did not ask me specifically, but I figured I would chime in.
In my opinion, you would need to build two equal length manifolds that were identical to each other with the exception of the collector. One would be a 4 into 1 collector for the open scroll and the other would be a 4 into 2 for the divided scroll.
The reason for the same design manifolds would be to insure that the header is not attributed to any power gains. Obviously a well designed TS header will preform better than a crappy open scroll header.
The reason for the equal length would be to insure that the open scroll would benefit from separate exhaust pulses like the TS artificially creates.
You would use ONE turbo and change only the turbine housings.
You would need to test ALL the turbine housing AR ratios available for both open and divided.
Each test should be done at two boost levels. One level representing average street boost and one level representing "race" boost levels.
Obviously, the same car would need to be used for all testing with nothing but the header and turbine housing being changed.
Testing on the same day with weather conditions being the same all day would be preferred.
Obviously this would be a huge undertaking with a massive investment in money and time. I would PERSONALLY help in any way I can.
what about tuning? surely you can't idealize one and expect no tuning on the other and you might not want to idealize neither...
Old Aug 29, 2007 | 09:05 PM
  #69
DTM's Avatar
DTM
I'll post and email you the results of the two manifolds that I finish this next couple of weeks. (getting ready for events as well)
I'll follow this procedure exactly as posted. After every scenario has been exhausted, we will post the results.
Old Aug 29, 2007 | 09:09 PM
  #70
Tom W's Avatar
It never hurts to re-tune your car, you should re-tune your car if you do something that well make your car respond differently then before.
I love these kind of threads, just be reading just a few post by Ivan i learned some much about TS and OS thanks Ivan
Old Aug 29, 2007 | 09:36 PM
  #71
Ivan@AMS's Avatar
Yes, tuning would have to be done. I would shoot for the same AF and timing for each boost level. Reporting on what tuning was needed for each combo would also show where the gains and losses are.
Old Aug 29, 2007 | 09:38 PM
  #72
trinydex's Avatar
sounds good to me...
Old Aug 29, 2007 | 09:49 PM
  #73
slowTsi's Avatar
Whatever, guys, I'm more stoked that I can get a gt4094r in an open t4 housing
Old Aug 29, 2007 | 09:50 PM
  #74
Tom W's Avatar
So will AMS be doing any TS tests for subie's at all?
Old Aug 29, 2007 | 10:07 PM
  #75
Tom W's Avatar
Ivan, correct me if iam wrong. From what i read on this thread, with a TS it is not for a drag racer but for a daily driver and road racer? You lose power and gain spool?
