Twin-scrool vs. Open scroll test!
When we were doing the turbos for GM Racing's Ecotec program for NHRA Sport Compact, we found that TS allowed the use of less boost builder when on the line. The engines started lasting longer as a result, since they weren't being worked so hard on the line. Boost builders are not gentle.
There was no penalty in trap speed as a result of using TS here.
I disagree, I would keep boost and timing the same and equalize the A/F ratio. If one housing is flowing more and making more power at high RPM's this will reduce backpressure. This in turn will reduce the amount of end-gas in the combustion chamber, which theoretically should allow you to run a little more timing. But also the reduced BP increases VE so you might need to run a little less timing... see where it gets complicated? You would need in cylinder pressure analysis to monitor pressure spikes (knock activity) to really bring each tune to it's max potential, big $$$ . Using a factory knock sensor at this level would not be accurate enough.
Now I took the point of this discussion to be which kit, flatout, performs better. I would take that to be pushing each of them to their given limit on a given fuel ona spec motor with the most evenly matched manioflds. If one creates more back pressure and starts to limit VE in the top end and more timing is needed than that is the downside of that turbo. Then again that makes for more variables to question the testing done.
So to be completely fair, I guess same A/F, timing and boost pressure would be the most straight forward test. Also as you well know timing will effect your A/F, so would you lock the timing map down and adjust a/f based soley on fuel...but then again fuel energy has been shown to help spool turbos. Regardless trade offs will be made in the testing.
In cylinder pressure monitoring would be the best way to monitor the testing...makes me wish I did the fiberoptic in cylinder pressure gasket as my senior project now
Oh, and how is the FSAE resume hunt going
-Micah McMahan
[quote=Ted B;4691371]It's funny how both of my setups also showed roughly the same thing when looking at the spool curve on a dyno chart. However . . . quote]
However your open volute was a T3, 35R and the TS was a T4 37R.
Maybe there is something to this TS thing
ill respond later, but this test isnt very conclusive... there are plenty of points to touch upon.
unless i am mistaken, both AMS and Ivan (AMS' head tech) are both in this thread saying twinscroll will spool earlier but in exchange for that earlier spool, there will be a power loss at high RPMs (i would agree with this statement under certain circumstances/test conditions, yet vehemently disagree under others). Additionally, they mentioned that twinscroll is not for drag racing...
edit: doesnt AMS and Ivan run twinscroll setups on their drag cars????
Paul, what was my advice when you called about which turbine housing to use? I want you to tell it so these guys don't think I'm biased towards one housing.
I do feel with the 1.02 housing the most we could have gotten is 950 whp on better cams maybe 55 psi of boost. After talking to TedB i really am thinking about ordering the 1.44 divided housing to see if i could make the same or more power with less boost and timing plus keep my spools about the same.
See guys
Thanks Paul. I also recommended the twin scroll over the open scroll as I wasn't convinced either way which one is better. I also think the twin scroll is a good option for the GT42R. I've made more peak power on the open scroll HKS housing compared to the 1.28 A/R divided housing on our drag car but our header is completely different so it's hard to equate the power differential. Maybe the 1.44 will make the power and still provide better spool, it's something worthwhile to try. Paul, throw that 1.44 on there and let us know how it does.
Me thinks you need a spanking.
I do find it interesting that most of the turbo ALMS cars, Rally cars, CHAMP CAR, use a an open scroll housing. I would figure that Audi with such a huge budget for the R10 TDI would use the best technology possible. Maybe the rules limit then to what they can run? Jason, you'd have some more insight then the rest of us on this one.
You'll shoot your eye out.
WRC cars use a small, restricted turbo. The problem they face is high rpm power. Already the cars make peak torque around 3500 rpm (and 40 psi of boost at that speed).
While TS isn't a new concept, it seems to me that the use and understanding of it for the type of applications we consider is relatively new and not widely understood. After all, Garrett only very recently revised the recommended engine displacements for their larger turbos, having seen us do things they never expected or would have recommended with their products.
