B.C. evo roll call
Old Nov 16, 2009 | 07:23 PM
  #136
vince126's Avatar
Originally Posted by AJR-Coco
My intake is sold ladies and gentlemen...
Stock boost supposedly should be 1.1 bar around 17 psi taper around 15 psi
23 Psi taper down to 20 psi sounds normal but cranking the PSI up i suggest you get a tune. AND your car will run really bad if you crank up your boost with no aftermarket exhaust
The exhaust basically help you get more air flowing out when there is more pressure. So basically the more psi with the TBE it makes a huge difference
By the way my turbo is for sale! i am going with an aftermarket getting my MR 6SPD reinforced by shepard and cranking it to 30 PSI
im on the works P2 flash, its suppose to be 20psi all day. and it was fine when i was in california, as soon as i put 94 oct + colder temp, i started seeing 23-24psi peaks.
i dont think its a real problem, but i would rather get a real tune and push out some more power.
as for the MTL and Mt90 good to see good results
Old Nov 16, 2009 | 08:58 PM
  #137
AJR-Coco's Avatar
A correct tune will always give you the max potential to your car! But i don't see why putting in 94 oct and colder temp will make you boost higher?
Old Nov 16, 2009 | 09:51 PM
  #138
007WRX's Avatar
The colder temp totally changes the density of the air. Thats why your car always feels faster at night, more boost!
Old Nov 16, 2009 | 09:56 PM
  #139
vince126's Avatar
Originally Posted by 007WRX
The colder air totally changes the density of the air. Thats why your car always feels faster at night, more boost!
QFT
i'll wait until i get a response from Works regarding the MBC before i throw it in. they use their own lines from the stock BCS, so i need to know exactly what they did anything else with the vac lines. i dont think its a problem since im removing the stock BCS out of the system completely, and the lines going to and from it.
the LICP can cause boost pressure to go up also, since there will be less piping in the intake charge. im lookin forward to seeing some good results...when it gets here anyways lol.
Old Nov 17, 2009 | 12:05 AM
  #140
AJR-Coco's Avatar
Sorry but what i don't understand is why would colder temp change the density of air would give you more boost?
I thought having colder air/temp will allow better cooling, which means the car would pull a little bit faster, but does not create more boost. The reason is because the engine wants to put more fuel to reach the operating temperature.
why would the air affect the boost i thought the boost was controlled by the actuator?
Old Nov 17, 2009 | 11:34 AM
  #141
samurai85's Avatar
OK so this still doesn't answer my question.
Why am I boosting 20psi spike to 23psi? Stock everything....NO MBC/EBC.
I thought evo's boost solenoid doesnt do ECU controlled boost, so i don't understand why I am boosting so high.
Old Nov 17, 2009 | 12:34 PM
  #142
vince126's Avatar
dont worry, most Evo IX do that, especially now that its getting cold. just keep running 94oct gas and wait for a tune, or run an MBC. the stock Evo does run extremely rich, so a temporary boost spike is really no concern as long as you run good gas.
as for boost increase i really cant get into any more depth than we already told you lol.
cold air is denser, therefore the turbo has become much muh more efficient by the time its 3500rpm the turbo would compress much more air volumn due to the fact that its denser than it would when it was hot out therefore reaching your targeted boost too fast and overshoots.
Your car sees this and quickly cuts the boost to protect itself.
you can google it if you wish, you probably find some better answers out there.
Old Nov 17, 2009 | 01:50 PM
  #143
apagan01's Avatar
Originally Posted by vince126
great idea, ive been really surprised lately of what Lordco can bring in lol, and they give awesome discounts to the military. I got a set of Hawks HPS pads for the Suby for 140$!!!
i just picked up Redline MT90 and Redline MTL for dirt cheap there. i think they will be my source of parts from now on.
ive been looking for the Vibrant MAF Adaptor so i can run Amsoil cone filter, but they said 3-6 weeks....at least they can get it.
the ricer in me likes to hear the WHOOOOSSSHHHH sound of the spool lol.
Get if from AMS i think is the same price, or lancershop.com for the MAF adaptor
Old Nov 17, 2009 | 01:53 PM
  #144
apagan01's Avatar
I am using MTL+MT90 mix in my MR tranny and its very smooth. I like it a lot. But i don't dare put anything but OEM fluids in the rear diff and transfer case haha i've heard of too many horror stories, even amsoil i'm afraid.
Many to many customers running the lfuid in the TC and rear diff and they have had zero issues, think about it synthetic VS non synthetic
Old Nov 17, 2009 | 02:17 PM
  #145
vince126's Avatar
i found a distributor in Edmonton that will ship amsoil stuff :X unfortunately it was too late, i already bought the MT90 and MTL from lordco with a good discount. I still wished i went with Amsoil instead, but Redline is fine.
BUT i ordered the Amsoil severe gear, got to my door for 30$ : / 12$ shipping is a little crazy. I was more worried about my Transfer case than the transmission since i still have the clutch pill in.
i just contacted lancershop and im sending them the money tonight
now all i need is the Amsoil filter!
Apagan you are just sneaky, popping up all over the place.
Old Nov 17, 2009 | 03:15 PM
  #146
samurai85's Avatar
Details on this clutch pill? I've read about it but forgot the details.
Old Nov 17, 2009 | 03:21 PM
  #147
josel_atr's Avatar
hey guys, go in the Northwest section, Aaron from ER just posted some details on the Dyno Day in Mid Dec.
Old Nov 17, 2009 | 03:23 PM
  #148
vince126's Avatar
i prevents the heavy shock load when you dropping the clutch (which you shouldnt) it prevents the clutch from transferring all the load traight to the transmission and transfer case, if your wheels dont spin. it delays full clutch engagement, so you'll burn your clutch instead of blowing up your T-case and or Transmission.
im going to remove mine when i put the SS Clutch line in, the pill itself is in the slave cylinder i believe, there are lots of instructions here on how to remove it.
it just makes the clutch feels much more predictable apparently.
Old Nov 17, 2009 | 03:36 PM
  #149
samurai85's Avatar
Interesting... thanks for the explanation. I just looked it up.
For anyone interested: http://www.evomoto.com/tech_info.php...=3_4&tech_id=4 , good read!
What do you guys think of the ETS intake filter?
Old Nov 17, 2009 | 03:54 PM
  #150
007WRX's Avatar
I have the HKS Hybrid filter in mine. Noticed a little increase in noise.
Random shot:
