cobb tuning accessPORT question
Old Mar 30, 2011 | 10:45 PM
EVOXMR10's Avatar
i just order a cobb tuning accessPORT and im going to be using it as my second map....
does anyone have there evo x tune (ECU reflash) and also have the cobb tuning accessPORT as a second map ?
so its like having dual maps
how do you like it ?
thanks
Old Mar 31, 2011 | 12:46 AM
BakaUnchi's Avatar
thanks
that is not possible, the accessport will flash over your ecuflash tune
Old Mar 31, 2011 | 08:13 AM
Golden's Avatar
But it will return your old map when you unmarry it.
Old Mar 31, 2011 | 10:09 AM
EVOXMR10's Avatar
yeah cause im going to have one tune on water/meth and have AP without the water/meth tune for my DD
Old Mar 31, 2011 | 10:31 AM
fostytou's Avatar
EvoM Community Team
.....or you could just use ECUFlash only (or AP only) and stick to one product so you don't have to constantly un-marry the device.
Better yet, tephramods will allow you to map switch on the fly without AP or a flash.
Note that constantly flashing your ECU can eventually cause memory errors (though we do it quite a bit and haven't run into many problems)
Old Mar 31, 2011 | 02:50 PM
Golden's Avatar
Yep, I agree. Stick to one platform.
AP can flash back and forth with multiple maps loaded on.
EcuFlash can flash back and forth with multiple maps (requires laptop).
EcuFlash can also use Tephra mods and allow swapping on the fly. (Best Bet)
Old Apr 1, 2011 | 11:05 AM
EVOXMR10's Avatar
so i can have dual maps on the AP ?
i have as well do it like that and just have my tuning on the AP !
my AP is coming tomorrow....i cant wait to play with it
Old Apr 1, 2011 | 11:32 AM
fostytou's Avatar
EvoM Community Team
You can have more than one map stored on the AP, but you will have to stop and flash each time you want to change it. It will cause wear on some of the memory cells in the ECU which may eventually damage it.
With ECUFlash you can currently change between 2 maps on the fly with the car running by holding down a specific button. Soon, you will be able to change between 9 maps.
Old Apr 2, 2011 | 05:51 PM
boostawd16's Avatar
yea way too much of a hassle unmarrying and marrying and unmarrying its not fun just stick to one tune
Old Apr 4, 2011 | 10:47 AM
EVOXMR10's Avatar
i drop off my car this morning and the shop guy said it better if i leave it marry at all time, so that what ill do
Old Apr 4, 2011 | 11:41 AM
kozmic27's Avatar
There is no reason why you cant have one of your AP maps be set up for meth. The AP wont allow you to incorporate the automatic failsafe map switching like the Ecuflash map will, but you can still tune a meth map on the ap. Switching maps via the AP is not that big a deal.
Old Nov 7, 2011 | 05:03 PM
jstride's Avatar
Agreed. Stick to one product. AP has limitations due to limited tuners familiar with evo's in particular.
Jakee
Jan 12, 2022 05:31 PM
keshav707
May 5, 2016 05:30 AM
OkcSupra
Cobb AccessPORT
27
Jan 15, 2012 09:05 PM
COBB Tuning
Cobb AccessPORT
21
Aug 12, 2011 09:18 AM
schumi
40
Sep 22, 2006 07:09 PM
