Cobb AP for 2011 Evo X?
Old Jun 17, 2011 | 06:16 AM
  #301
sfearl1's Avatar
will there be a stage 1 93 octane map?
Originally Posted by BakaUnchi
The rpm scaling is a bit off since the Dyno rolls weren't quite synced to RPM for some reason
Peak boost/tq is 3000 ish
peak HP is @ 6500-7000
THE CLOSE DOTTED LINE IS OTS MAPPING
THE SOLID LINE IS NOT THE OTS MAPPING (yet)
the gains over stock on Stage 1 ACN are approx 10-11% over stock
take whatever baseline you find on a 2011 and add 11% (For the Stage 1 OTS map)
i saw a car baseline @ 269 +11% = approx 300
These are from my preliminary testing on ACN 91
Once the dyno is back up in socal I will RE dyno all
the maps so we can have gains over a stock 2008, 2009, 2010, and 2011
Please remember the early 08 flashes suck compared to the latest 08 flash too
so baselines will vary but ill test every Stock Rom on each car to see the gains
Old Jun 17, 2011 | 07:57 AM
  #302
jthompson8692's Avatar
So, it looks look stage 1 flash will see gains over the 2011 factory tune....
Old Jun 17, 2011 | 11:37 AM
  #303
BakaUnchi's Avatar
Yep there is its in the firmware for release
Old Jun 17, 2011 | 12:15 PM
  #304
guswaym's Avatar
Will the stage 2 Gsr maps come out the same time as the stage 1?
Old Jun 17, 2011 | 01:01 PM
  #305
Optiblue's Avatar
Patiently waiting
Old Jun 17, 2011 | 03:12 PM
  #306
rmondoh's Avatar
Random question concerning the AP itself. I have an older version of it (without the black connector sticking out at the bottom. USB connectors only). Will the new firmware update allow me to log more entries like the newer AP's. I remember logging a couple times and my log for a 3rd gear pull had less than 20 or 25 entries in the excel sheet. Is that a limitation of the device itself or the firmware?
Old Jun 17, 2011 | 04:04 PM
  #307
BakaUnchi's Avatar
the older V2 (not V2B) Do log a bit slower currently (thats why we moved to the new cables)
There are some more logging improvements coming down the pipe, ala GT-R style logging which is now up to 39 items @ 34HZ i believe !!
does that ?
Old Jun 17, 2011 | 08:14 PM
  #308
Golden's Avatar
What is up with Cobb's website?
Old Jun 17, 2011 | 08:21 PM
  #309
Kracka's Avatar
Been down for two days
I've been itching to get on their dyno-database to see all the charts from last weekend's dyno-day.
Old Jun 17, 2011 | 09:09 PM
  #310
BakaUnchi's Avatar
i was perusing them today........
Old Jun 18, 2011 | 08:50 AM
  #311
RAPTR's Avatar
Use whatever map you want but it it blows up
We only have stage 1 2011 GSR right now
but it will work well on stage 2 Cars as well
Again the 2011 maps are designed by ME
not the same tunes as the 2008-2010
Does this mean the MR maps are not going to release at the same time as the GSR maps?
Old Jun 18, 2011 | 02:42 PM
  #312
BakaUnchi's Avatar
NO
we only have stage 1 gsr maps right now (stage 2 coming asap)
RA and MR have stage 2
Old Jun 18, 2011 | 03:43 PM
  #313
sfearl1's Avatar
did you happen to get a stage 1 Cosworth drop-in map ?
Old Jun 18, 2011 | 05:34 PM
  #314
BakaUnchi's Avatar
i have that .........
hehe
Old Jun 18, 2011 | 06:07 PM
  #315
WWGSR11's Avatar
hehe
What about k&n drop in? Just regular stage 1 map?
