Cobb AP for 2011 Evo X?
Old Aug 14, 2012 | 07:54 PM
  #1231
slightlyremoved's Avatar
I have been reading this for over a year and a half now. I spent 600 and i cant even use it.
Originally Posted by COBB Tuning
Currently, the AccessPORT for the 2011 EVOX is not yet available. However, the same AccessPORT part number AP-MIT-002 will carry over to the 2011. We will make a formal announcement when the firmware update is available!
Travis
COBB Tuning
Old Aug 15, 2012 | 05:01 AM
  #1232
BoosterX's Avatar
That might be a bit of an exaggeration. You can use it. The v202 maps are fine..
Old Aug 17, 2012 | 03:36 PM
  #1233
BeyondLimitsEvo's Avatar
Originally Posted by DocBoz
they seem ok you should log rpm as well it seems your getting a few counts of knock at what im guessing is around 6-7k but 1-2 counts i wouldnt worry about
Thanks! I actually got rid of the MR a few weeks ago and got a '12 GSR. I'm waiting to break it in a little and then put up some logs.
Old Aug 18, 2012 | 02:03 PM
  #1234
ethics's Avatar
They have severe shifting issues! I feel the pain.....
Old Sep 16, 2012 | 09:39 AM
  #1235
Atlevox's Avatar
I just downloaded the 2 media share maps that "bakaunci" created before for the 2011 Gsr with injen on stage 2 and I'm boosting high. Anyone know if he has a "LWG" option somewhere.
I removed my protuberant that I had w my 3 port and am using his the tune bakaunci made for the injen stage 2 . Honestly that 2 is so much better than the pro tune I got . I just don know the peak boost descriptions on his 91 @ 93 tune . Cus on 93 I'm hitting 29-30 & on 91 I'm hitting 28-29 . I love this tune so much better but just need a 91 &93 LWG option to reduce overboostin. I tried to email him but I'm not able to reach him any one know how to contact him . His tune for my injen stage 2 was so much nicer than my protune.
Thanx Marx
2011 Gsr Evo x
Injen intake
Injen uicp
Hks ssqv3 with hard pipe recirc kit
Hks hi power exhaust
Ets 200 cel hi flow cat
Cobb AP
Looking to sell :
Slightly used 3 port grimspeed
Brand new Works under hood bushings
4 - oem great condition GSR rims
Old Sep 17, 2012 | 03:41 PM
  #1236
BoosterX's Avatar
Only the Normal mode sucks bad. If you have it in S-SPORT or manual Sport it's fine.
Not the greatest answer, but new maps soon to fix the shifting.
Old Sep 18, 2012 | 04:26 PM
  #1237
tnn35's Avatar
I'm with you on this. I ran v303 from bakaunci released last september for more than 6 months. Everything was fine, boost up to 29psi. AFR is perfect. MR transmission is stock but has no shifting problem.
I got my car with boost pill removed for v202 and now CBCS so I can't go back to that map. v202 feels much slower. boost is around 22psi only. AFR is very rich.
if cobb not release anything in 1 or 2 months , I may put everything back and run that map again. or just go protune.
Thanx Marx
2011 Gsr Evo x
Injen intake
Injen uicp
Cobb AP
Looking to sell :
Old Sep 18, 2012 | 05:43 PM
  #1238
MisterHappy's Avatar
Might want to run a boostleak test, 22 psi is well under the target boost. I am on the stage 2 and hit 26 consistantly.
Old Sep 19, 2012 | 08:16 AM
  #1239
1010's Avatar
Originally Posted by misterhappy
might want to run a boostleak test, 22 psi is well under the target boost. I am on the stage 2 and hit 26 consistantly.
+1
Old Sep 23, 2012 | 09:42 AM
  #1240
tnn35's Avatar
how would I do that? I checked every pipes they seem fine (still running rubber ones) I'm thinking of replace hard pipes... do you think that would help?
Old Sep 23, 2012 | 10:04 AM
  #1241
Kracka's Avatar
Guys, keep in mind that every car is different, and differences in air temperature and elevation will have an impact on peak boost.
A protune is always going to be your best choice since your car will be dialed in perfectly for all the variables, but if you were happy with the v303 and want to save the cash just go back to it.
Old Nov 6, 2022 | 09:42 PM
  #1242
BoriEvo's Avatar
Originally Posted by Golden
Same tune. Virtually identical. 2010's get lean spool.
Maybe that's what you meant...
I can’t see the map can you send it
whatever210
For Sale - Cars For Sale
Sep 28, 2016 12:32 PM
granelli
Jul 5, 2014 06:23 PM
Ruthless.
Jun 7, 2011 08:53 PM
416_EVO
Toronto Lancer Club
15
Apr 24, 2011 11:16 AM
Chang_Wufei_05
Nov 15, 2010 11:46 AM
