Cobb AP for 2011 Evo X?
Old Jun 24, 2011 | 05:12 AM
  #391
MikeD's Avatar
Nice numbers! Is there going to be a Cosworth Drop in filter map?
Old Jun 24, 2011 | 05:57 AM
  #392
EVOXcellence's Avatar
Originally Posted by BakaUnchi
Thank you for posting the comparison, but now I am confused, if you check on pg. 7 you will see a base map for a Canadian 2011 GSR from a reputable tuner, Magnus Autosports, run on an AWD Dyno Tune.
As you will note the stock tune on the Canadian model is very very close to the Stage 1 Map just posted by Cobb. Is it that the US version or California Version has the same tune as the 2010 and does not benefit from then same tune as the 2011 Canadian tune?
If I had a Cobb unit I would gladly back up the Map so you could look at it.
Anthony
Old Jun 24, 2011 | 07:31 AM
  #393
Kracka's Avatar
Every dyno reads differently, I believe Magnus has a Dynojet which reads higher than a Mustang dyno (what Cobb has). You want to only compare numbers from the same dyno, and 260/283 is a stronger tune than the 2008 or 2010 got so that's a great sign right there that Mitsu improved the 2011's stock tune. The gains Jon has accomplished on an otherwise stock car are also very nice; smoother powerband with gains throughout.
Please also do not confuse the terms "AWD dyno" and "AWD dyno tune." Dyno tune implies the car was tuned when in fact that chart on page 7 you refer to is just a dyno baseline run.
Old Jun 24, 2011 | 07:42 AM
  #394
Understood, well it will be very interesting to see what Numbers come off the Dynojet after I procure a Cobb unit and load the new map, I will backup the stock Map just in case.
Anthony
Old Jun 24, 2011 | 07:46 AM
  #395
RAPTR's Avatar
NO
we only have stage 1 gsr maps right now (stage 2 coming asap)
RA and MR have stage 2
Is there anyway we could see the dyno charts for the Stage 2 MR/RA? Or anything MR/RA related?
Old Jun 24, 2011 | 07:47 AM
  #396
Kracka's Avatar
Anthony
The AP unit automatically saves your stock tune so you can return to stock at anytime. With Dynojets reading higher than Mustangs don't be surprised if your gains look even better than the ones above on a Mustang dyno.
Old Jun 24, 2011 | 09:22 AM
  #397
jthompson8692's Avatar
Please!
Old Jun 24, 2011 | 05:29 PM
  #398
guswaym's Avatar
is it out yet!?
Old Jun 24, 2011 | 06:21 PM
  #399
twokrx7's Avatar
So the xtra power is coming from the higher boost? Or is the AFR all over the place on the stock tune?
I cannot wait to hear more about how the maps change the car at launch, are all transmission modes remapped?
Old Jun 25, 2011 | 02:32 AM
  #400
BakaUnchi's Avatar
that dynochart has an AFR of 10.8:1 :-D
there is plenty of wiggle room
Old Jun 26, 2011 | 03:01 PM
  #401
guswaym's Avatar
soon?
Old Jun 26, 2011 | 04:36 PM
  #402
BakaUnchi's Avatar
Originally Posted by guswaym
soon?
i think you guys will be pleasantly surprised very soon
Old Jun 26, 2011 | 05:07 PM
  #403
sfearl1's Avatar
x2 !!
Old Jun 26, 2011 | 05:08 PM
  #404
guswaym's Avatar
good to hear another question i have full bolt ons will i be able to use the stage 1 safely untell the ots stage 2 comes out?
Old Jun 26, 2011 | 07:23 PM
  #405
Golden's Avatar
Mar 18, 2011, 11:49 PM:
Originally Posted by COBB Tuning
Soon guys don't lose hope.
Field testing is currently underway!!!
Mar 20, 2011, 04:26 PM:
Dont worry buddy it will have a tune VERY soon.....
Apr 9, 2011, 12:55 PM:
made large steps fwd yesterday, coming soon guys!
May 13, 2011, 09:50 PM:
I dont think you guys get it. If the software were done in order to produce the map to flash the car i would have them out to you last month. The software needs to produce eh right files to flash the car properly, we have been clearing bugs and old code to get everything just right. I cant put a map on a car that might not work because of a bug. As soon as its fixed and tested it will be delivered. Soon means SOOOOON like real soon not far away soon
Jun 14, 2011, 02:39 PM:
Fixed a few logging bugs because of a USB cable
Real soon guys!
Jun 26, 2011, 06:36 PM
