Cobb AP for 2011 Evo X?
Old Oct 2, 2011 | 09:22 PM
  #961
oozkarao's Avatar
Originally Posted by evo_xtc2011
I get a code PO420, Catalyst system efficiency below threshold.(bank 1..or is it 2?). I have Cobb high flow cat, don't know if that will be the cause, and my car has less than 1k miles on it.
I got the same code, too. The regular stage 2 maps disable that code as far as I've seen from the map notes. Perhaps they used a test pipe (like those with 'j' shaped O2 bung) that does not trigger the code, so they did not have to disable it during their testing.
Would it be possible to update the maps and disable the code?
Old Oct 2, 2011 | 10:16 PM
  #962
BakaUnchi's Avatar
i may have forgotten to check that box?
ill check tuesday and let u guys know
Old Oct 2, 2011 | 10:59 PM
  #963
BakaUnchi's Avatar
Updated to fix CEL on stage 2 GSR ONLY
Originally Posted by BakaUnchi
2011 STAGE 1 ALPHA STOCK, INJEN AND COSWORTH PANEL INTAKE MAPS
FOR MR ONLY[/size]
http://www.mediafire.com/?eg6qbap1koxc3
2011 STAGE 2ALPHA STOCK, INJEN AND COSWORTH PANEL INTAKE MAPS
http://www.mediafire.com/?5bupofiny2ug7
STAGE 1 is STOCK or INTAKE
Stage 2 is:
Old Oct 2, 2011 | 11:53 PM
  #964
oozkarao's Avatar
Great, thanks man! I'll update my map right away..
Old Oct 3, 2011 | 12:05 AM
  #965
oozkarao's Avatar
Oh, and for fun, below is the v-dyno result of a 2nd gear pull (2011 Cosworth Stage 2 91) :P
I used 3650 lbs as the weight (3451 with my spare tire delete, etc. + my 200 lbs weight).
Old Oct 3, 2011 | 01:36 AM
  #966
BakaUnchi's Avatar
what software is that?
Old Oct 3, 2011 | 03:40 AM
  #967
oozkarao's Avatar
That's just the dyno data from AccessPort's virtual dyno feature. I plotted the data on a graph using OpenOffice.
Old Oct 3, 2011 | 12:19 PM
  #968
guswaym's Avatar
those virtual graphs look so similar to my real graph gotta love math!
Old Oct 3, 2011 | 05:50 PM
  #969
packrat's Avatar
Can anyone shoot me a link to download the 93 and 91 oct stage 1 maps? Looked through this thread and on Cobbs website and no luck? I'm guessing I totally missed it????
Old Oct 3, 2011 | 07:21 PM
  #970
BakaUnchi's Avatar
included on the accessport when u marry it
Old Oct 3, 2011 | 07:25 PM
  #971
user 629782012's Avatar
its in the post above with the colourful pictures etc etc. click on the big bold text
Old Oct 3, 2011 | 07:59 PM
  #972
aznnightkidz's Avatar
so cobb works with 2011 gsr now?
Old Oct 3, 2011 | 08:09 PM
  #973
guswaym's Avatar
has for like 3 months ...
Old Oct 4, 2011 | 12:07 AM
  #974
oozkarao's Avatar
I think packrat is rather asking about how to get the beta firmware.
BEFORE you even marry your AP, you need to upgrade your AP handheld device to the beta firmware:
  • Install AP Manager to your PC, go to "Options".
  • Choose "Check for beta software". Then check for updates. It will now find the beta firmware and will ask to upgrade your handheld device.
  • Once done, you can then marry your AP and you'll have the v300 beta maps available.
I think Cobb should post these instructions somewhere (if not already) since it is not really clear what to do looking at the release notes page.
Old Oct 4, 2011 | 03:24 AM
  #975
packrat's Avatar
Thats what I was looking for. Thanks oozkaro. Just ordered the Perrin stage 1 for my 2011. They don't have a map for it yet and I'm just not sure whats going to be on the unit when I get it.
