AccessPORT and AccessTUNER Updates for Mitsubishi EVO X and Ralliart
I've been running the old stage 2, but i was seeing 28psi on it. Will this new map make my boost spike even higher?
I'm running 2010 evo x aem stage 2 TBE acn91 version 1.08 but I just updated the accessport tonight. I'm gonna reflash in the morning.
Be warned that the only tunes they have available right now are the ones for STOCK INTAKE AND FILTER. They are working on the intake ones and they will be done in a week or so. I asked if we could use those even if we have an intake on, and he said that you might throw a code for being lean at idle.
I just reflashed to v200 stage 2 ACN 91. The only thing I notice so far is it runs pretty rich. AFR is at 10 on every boost. I was running v302 stage2 injen intake, it was around 10.5 -> 11.
I have full cat back + password jdm intake.
so I probably will switch back running v302 LOL
ALSO, you said you are running a full CAT-BACK, are you sure you don't mean Turbo-back? I would assume that if the car thinks you have a turboback and you don't, it will be dumping more fuel in than is needed. Should try the stage 1 map.
Coz at WOT, I see constant 10s, will running regular 91 yield better results? Meaning not running rich?
I'll have it running for a week and see what's going on. most likely I may try normal 91 too.
Well I am running:
K&N drop in
Resonated test pipe
Modified muffler
I am currently running the HKS 93 stage 2 tune with the boost pill in. My logs are on here. I tried the SF 93 stage 2 tune and had alot of knock so I stuck with the HKS cause I had good results.
K&N drop in
Resonated test pipe
Modified muffler
You are trying the beta maps? there are no intake maps out for the beta maps yet from what I understand... You sure you are trying the 200v maps?
