AccessPORT and AccessTUNER Updates for Mitsubishi EVO X and Ralliart
Old Jul 17, 2012 | 08:49 AM
  #91
RAPTR's Avatar
Originally Posted by tnn35
So finally I have my CBCS installed and running v202 stage 2 with CBCS map. Boost is 2psi higher than the normal map at around 22psi (this is what I see on my analog gauge during boost). It looks solid so far.
I'll try to do some logging later today...
When you get a chance to log, post them up on the Cobb forums too so Braden can see them. I'm only hitting 23psi on my CBCS map but I thought target was 25psi.
https://forums.cobbtuning.com/forums...Evolution-X-MR
Old Jul 17, 2012 | 06:02 PM
  #92
tnn35's Avatar
are you running with CBCS ? I was able to do some logging. Boost was briefly and drop down to 23 and stay there. knock was 1 and 2 but mostly 0
Old Jul 18, 2012 | 07:04 AM
  #93
RAPTR's Avatar
Yes.
Old Jul 18, 2012 | 09:48 AM
  #94
tnn35's Avatar
Yes.
would you please share picture of your CBCS installation? I just want to double check if mine done correctly. Just 1 picture where CBCS sit on top of the other controller.
thx
Old Jul 18, 2012 | 01:26 PM
  #95
RAPTR's Avatar
thx
If I can remember to do so I will or you can post your install. Are you worried about how you mounted it or the vacuum lines?
Old Jul 18, 2012 | 05:36 PM
  #96
tnn35's Avatar
so the installation looks like this:
botom controller has a disconnect vacuum line, does that look right?
Attached Thumbnails AccessPORT and AccessTUNER Updates for Mitsubishi EVO X and Ralliart-img_2448.jpg
Old Jul 19, 2012 | 10:16 AM
  #97
RAPTR's Avatar
The bottom controller isn't used anymore so disconnect all the left over vacuum lines from that unit. All used vacuum lines go to the 3-port.
Old Jul 19, 2012 | 01:00 PM
  #98
tnn35's Avatar
got it. Thank you
COBB Tuning
Apr 13, 2016 12:53 PM
COBB Tuning
Cobb AccessPORT
57
Jan 23, 2014 09:56 PM
COBB Tuning
31
Feb 26, 2011 03:48 PM
COBB Tuning
Nov 16, 2009 09:35 AM
COBB Tuning
Sep 4, 2009 09:10 AM
