Stage 3 + 4" Intercooler = Knock
Old Apr 1, 2016 | 06:17 PM
commbubba19's Avatar
Running stage 3 adj for KN intake. Ran great.
Installed a 4" intercooler and LICP and now under load/boost above 4k i get the SES flashing quickly and I can hear the knock. Engine seems to cut out a bit and I can see smoke briefly out the exhaust. Could be black (rich) or oil blow by due to the aggressive cutting out.
I only tested this a few times just to be sure.
So now i'm not certain where to go from here. I really didn't think the Intercooler would throw the Stage 3 tune off that far to require adjusting. However, boost mapping could be off but I don't even break 15lbs before this starts happening.
Mods as follows:
UICP, 4' Intercooler: LICP, KN Intake, HFC Test pipe, Borla C/B, Cobb EBCS
I've read guys running similar setups with no tune and thought not optimum, not having issues like this. But the Stage 3 is more aggressive so I'm assuming I'm either running too much timing, or the timing is off, and/or boost and fuel maps are off.
On top of all that my AP OBDII connector looks like it got damaged. Time for an upgrade I think.
Old Apr 2, 2016 | 10:03 AM
rico05's Avatar
I ran an OTS Stage 3 corrected for AEM with an ETS 3.5" and no issues. I am ProTuned now, but that is odd. Are you logging boost/knock/etc? The FMIC is less of a restriction, so in theory you should build more boost earlier.
Old Apr 3, 2016 | 04:36 PM
Yeah. That's what concerns me. Seems odd to be knocking and coughing under load just after an intercooler installation. That's what made me question if i missed something during the install.
Old Apr 4, 2016 | 02:32 PM
rico05's Avatar
Check all your connections for a leak and log some pulls. Need to know where it is kocking and and what your boost is doing to really know what is up.
I would 5-10 counts at WOT in the upper range of 5th gear before a ProTune. But nothing that bad.
Old Apr 4, 2016 | 05:36 PM
This is basically what my car is doing but occurs at more than 1/2 throttle too but is far worse at full.
Car was fine before the intercooler install, like this after.
Checked FPR vacuum hose and its secure. I checked all 4 plugs and they are clean. No broken porcelain and the gap is consistent across all 4.
I double checked everything I removed and it's all secure. Really the worse case I should have is a boost leak and there are none. I've had a boost leak before and it didn't cause this.
I'm waiting for my replacement v3 which should arrive later this week and then I hope to do some pulls / logs.
johnson81420
14
May 5, 2019 06:12 PM
thedru13
Nov 3, 2014 08:58 AM
Crester
Nov 17, 2010 08:09 AM
Peteypab2133
Future Lancer / Evo Models
31
Oct 5, 2007 06:03 AM
yoyoyoyoming
Aug 1, 2004 06:59 PM
