My new times for my evo 9
Old Feb 27, 2006 | 05:18 PM
  #106
dsmfan95's Avatar
Originally Posted by ~EVILEVO~
I ran 12.8@107 Stock, with a 1.7 60'
Warr....READ ..... i did run 12.8@107 with just a flash and hose mod
Old Feb 27, 2006 | 05:31 PM
  #107
PatNy's Avatar
pretty impressive times!
Old Feb 27, 2006 | 05:45 PM
  #108
.MM's Avatar
.MM
11.9 on snow tires....
jesus
Old Feb 27, 2006 | 06:13 PM
  #109
Rnm's Avatar
Rnm
Originally Posted by dsmfan95
Pwn't.
Next time clarify what you meant because a flash and that boost hose is clearly not stock!
Old Feb 27, 2006 | 06:14 PM
  #110
rodman's Avatar
Interesting stuff. I'm thinking above the great mods and driving I suspect the close ratio 5 speed and added torque from the Mivec and turbo give the car what it needs to get into the 11's on min mods. If you look at the ratios from 05-06 you will notice that...
1st gear (triple syncro) on the 06 is taller than 05 (2.785 vs 2.928)
2nd gear (triple syncro) is the same (both 1.950)
3rd gear (double syncro) on the 06 is shorter (1.444 vs 1.407)
4th gear on the 06 is shorter (1.096 vs 1.031)
5th gear (not used but shorter) 0.761 vs 0.720
I'm thinking the 9s 5 speed gearbox is even better than the MRs 6 speed Def better than the 03-05 5 speeds for sure. By the #s hova00 pulled out I must say the new 5 speed must shift slick as hell in stock form.
1st gear on the 06 is taller than MR ( 2.909)
2nd gear on the 06 is shorter than MR (1.944)
3rd gear on the 06 is shorter than MR (1.434)
4th gear on the 06 is taller than MR (1.100)
5th gear on the 06 is shorter than MR (0.868)
6th does not matter but the MR is 0.693
Seems like a MR 6 speed tranny could not get the job done unless it was in 5th gear. Paired with the same engine it makes me wonder if a MR 6 speed would be better or worse
Old Feb 27, 2006 | 06:47 PM
  #111
EvoBroMA's Avatar
now that would be depress me!
Old Feb 27, 2006 | 06:58 PM
  #112
Jeff_Jeske's Avatar
jesus
That's my favorite part! That should be his sig!
Old Feb 27, 2006 | 07:04 PM
  #113
Smogrunner's Avatar
jesus
Not too many people have figured out that snow tires (ie all season radials) are often faster than r-compounds. Think about it and tell why. If you are right, I'll paypal you a penny.
Old Feb 27, 2006 | 07:15 PM
  #114
Evo23IG's Avatar
Yeah, that's a LOT higher than other IXs on 93oct. Something has to be different. Also, no one ever dynos 355 at TT then traps 116. 355whp dynos at TT usually get 113-114mph traps. That's the weird part.
No thats wrong, Superhatch, dynoed at TT and put down 355 on pump then ran 11.9@116. Here is the proof.
https://www.evolutionm.net/forums/sh...highlight=11.9
Old Feb 27, 2006 | 07:16 PM
  #115
Warrtalon's Avatar
I'm glad the rest of you noticed his lie.
Old Feb 27, 2006 | 07:24 PM
  #116
Warrtalon's Avatar
I didn't see any dynosheets in there showing that he did 355whp uncorrected in the same conditions as when he hit the track, nor do I know if he's full weight like Hova. Also, there are many, MANY contrary examples where people have more WHP than this and lower trap speeds.
None of it adds up so far:
- Making 20-30whp more than other IXs with the same mods
- Somehow gained ~3mph after a few runs with no changes
- Somehow trapped 116 in 4th when the gearing says otherwise, and since when does TT set the rev limiter to 8k or higher? Is that normal for a regular flash on a lightly-modded car?
- He said he stayed in 4th but shifted at 8k? What does that mean? He shifted each gear at 8k?
- Even on the IXs, there is no power from 7500-8000, which is the section that would have pulled him to 116mph
I don't know. Maybe he needs to go to a different track to ensure the timers were working. Seems unlikely, but I have proof of a messed up timeslip in my sig. I by no means hit 115.7mph, but I could claim it if I wanted to.
Old Feb 27, 2006 | 07:31 PM
  #117
hova00's Avatar
Old Feb 27, 2006 | 07:33 PM
  #118
~EVILEVO~'s Avatar
Warr, more fanbois I see, you know what i ment, ME and YOU talked about this many times before! My car ran a 13.2 with no flash, and 12.8 with the flash and removing the pill. By stock i ment no TBE, drop in or any HARDWARE MODs.... I could careless how many of you rip apart my mods and fight about what whos got Now that my ~EvilEvo~ stage one package is complete, Warr you can come through anytime
Old Feb 27, 2006 | 07:34 PM
  #119
hova00's Avatar
I hope your not referring to me. First of all i have no reason to. Second i think that you may be a little jealous. Third you had responded to one of my previous posts and said that you are going to get a ix and run 12.7 stock and run 11's with the same mods i have. Why would you of all people even say that if you didnt think it was possible. Now you can believe what you want to, but i will go back to the track and try to duplicate my results for all of you naysayers and then hopefully there wont be anything else to raise any ?
Old Feb 27, 2006 | 07:41 PM
  #120
~EVILEVO~'s Avatar
Yo Hova, dont mind Warr, Hes got nothing better to do then to sit here and pick apart your times, my times, and anyone whos faster then him Nice times bro my track is closed till march 10th, but i will be there with the same mods you got to see if i can catch up to you keep it up
