1st time racing evo
Old Jun 12, 2006 | 09:32 AM
theEVOdream's Avatar
1st time racing evo
Went down to the local track here in Fayetteville, NC and got to finally race my evo. It was my first time launching an AWD vehicle so the times may be a little low as I was expecting to get better times. The best time I had was a 12.9 @107 reac: .697 and 60' was 1.8...1/8 was a 8.3. All my other times where in the 13.0 and 13.1's. Like I said I was hoping for better times but the track temps I think were somewhere in the 100's and it was about 95 that day with killer humidity.
My mods are intake, evo9 bov, 3" tb exhaust w/test pipe, 255 fuel pump, mbc @19 psi and a dynoflash w/2-step launch control. Anyone think I could have done better with this setup?
Old Jun 12, 2006 | 09:36 AM
KOEvo's Avatar
Given the conditions you sound pretty close. I would hope for a 12.7 in those conditions. Your car should be a low 12 second car with a good 60' and decent atmospheric conditions. We just saw a 12.49 w/ a dynoflash and intake, so expect a low 12's.
Edit: He ran 12.69 w/ a flash and a MBC. So you're looking at 12.3.
Old Jun 12, 2006 | 09:38 AM
Rnm's Avatar
Rnm
Why do you have it lower than stock boost?
Old Jun 12, 2006 | 09:51 AM
its at 21....but it always tapers to 19 the conditions totally sucked. I probably wont race again until the fall, not really worth beating on the car with this heat.
Old Jun 12, 2006 | 11:40 AM
NIevo's Avatar
Times seem about right for the weather conditions. Your traps are fairly good for your mods and are good enough for 12.4's-12.5's. Just work on your launch and shifting and you'll be golden
Old Jun 12, 2006 | 02:55 PM
Warrtalon's Avatar
That's a good trap speed for those conditions. If you're running 21psi, then you're running 21psi. We all taper, so that's no different. Don't refer to your boost as the taper point - refer to it as the high spike. Remember that you are never below 5500rpm on the drag strip, so you will only see the tapered boost level.
bbyct9agsr
Jan 6, 2008 05:07 AM
Charlie_B
10
Jul 1, 2007 06:49 PM
groove304
Mar 12, 2007 06:46 PM
Doug88
Oct 29, 2006 12:35 PM
xkpbreaker
Nov 15, 2003 11:16 PM
