How can I do better?
Old Sep 28, 2006 | 05:46 PM
FastAzzEvo's Avatar
I think she has more in her, but I am pretty happy with the results. I would like to get into the low 12's though with the same mods. Is it possible?
06 evo ix, esperlir downpipe, megan racing test pipe, megan racing catback, works p2e flash.
Launch was at 6K limiter
r/t .626 .489
60 1.837 1.800
330 5.334 5.304
1/8 8.213 8.184
mph 84.82 84.87
1000 10.688 10.672
1/4 12.753 12.753
mph 110.81 109.80
How the hell I had the exact same 1/4 time is beyond me, freaky i tell ya. I like consistency. Just wouldl like to get into the low 12's with my mods.
THanks,
Old Sep 28, 2006 | 05:51 PM
PhoenixEvo's Avatar
Well the funny part is your early shifts seem to be off cause your 1/8 mph doesnt match your 1/4 mile traps. normally people trapping 110 will trap 1/8 mile @ 86. Also with those traps u can for sure see atleast 12.4. But With the mods u have, the 9's i seen will trap 112.5 on pump gas and 114 on race gas. I assume u r running pump gas with psi of 22-23lbs?(this is due to not seeing a boost controller in your mods.)
Old Sep 28, 2006 | 05:58 PM
FastAzzEvo's Avatar
Yes, i'm running works P2E flash w/boost tube. It spikes at like 22 but stays 20psi or so to redline (computer controlled w/o a boost controller).
I think I am short shifting my 1-2 shift. Around 7K or so on my 7800 flash revlimiter.
I am on pump 93.
Old Sep 28, 2006 | 07:17 PM
NIevo's Avatar
Well with your mods you dont want to shift much past 7000rpm as theres not much power left. Your 1/4 traps are very nice, low 12's are a possibility with those speeds. A decent launch alone will get you a 12.5 or so.
Old Oct 4, 2006 | 07:42 AM
EVOB23's Avatar
Well from what I understand they say the 9s have lower gear ration so shifting higher is not that much worse. Me myself i alwasy kept my shift at 6800 with the stock cams. The only think you need is the launch and your car should run low 12 maybe a little bit more boost and you can hit 11's its pretty easy these days for such a thing.
Old Oct 4, 2006 | 08:37 AM
EVIL_EVO_VIII's Avatar
You should be able to hit low 12s... I ran 12.50 @ 110 and i trapped 89.58 in the 8th back in May, so its definitely possible
Old Oct 4, 2006 | 08:53 AM
16ggst's Avatar
seems like you might be shifting too slow?? i did a 12.4@109 1.70 60' and a 12.5 @ 110 with a 1.816. so the trap is there and the 1.80 60's arent terrible so your losing it before the 1/8th
Old Oct 4, 2006 | 09:01 AM
EVO<VR4's Avatar
Work on your 60' and you will meet your goal. Make some adjustments such as lower tire pressure, dont lift to shift, etc.
surferjeff
Apr 27, 2015 01:02 PM
TakaseEVOIXSE
Aug 5, 2007 10:56 PM
broeli
Jul 26, 2005 11:08 PM
EvilDylan
May 26, 2004 05:44 AM
EVOlunchbox
Apr 14, 2003 12:51 AM
