275 hp spinning off the line?
Old Jan 7, 2007 | 07:53 AM
Srt-4 Turbo 7's Avatar
Originally Posted by SmikeEvo
flevo8 - please write (or post) your time slips. And what RPM where you shifting at?
Basically, sounds like you dont have launching down yet. And may be shifting too high (out of the powerband). Which is fine - just need some more seat time. 2x down the track is not enough to get it right.
When playing with tire pressure - its best to only go in +/- 2 psi at a time. Look to your 60' for where to go on that and also feel. Too much grip or too little air can have negative results.
Could also have been track prep. I have experienced this on tracks that are heavily prepped for high hp rwd (tiretack). I spun, got stuck in the velcro, bogged.
5500 should be ok. I use the stock 5k and my best 60' is 1.61, usually I am around 1.62-1.65.
EDIT: Here is a link to my 2step tech.
https://www.evolutionm.net/forums/sh...75&postcount=4
Hey thanks for that 2step link
Old Jan 7, 2007 | 08:33 AM
mdog's Avatar
If you have not done it yet, and SS clutch line with no restrictor pill would be advisable. Should give you more cosistent feel with the engagement and removing the pill won't restrict the fluid.
Old Jan 7, 2007 | 11:05 AM
jrsimon27's Avatar
i have done multiple 7000rpm launches with my stock clutch i dont dump it just release it very fast with my foot on the pedal and nothing has happened spining the tires is good for the drivetrian you dont damage it here is a video of japanese launch the evos:http://www.youtube.com/watch?v=sBka-8ViOEU
in my opinion i wouldnt remove the restrictor pill it protects your transfercase just run a bit more air in the tires and launch higher at 6500rpms i think this will lower your times!
Old Jan 7, 2007 | 12:49 PM
4WS Tuning's Avatar
i didnt know this was at bradenton...... thats a really good track... with my car and a 6k launch i barely spin....
idk..... i think you might be burning clutch, not tires
Originally Posted by flevo8
Thanks for all the replies, I'll try to find one of my times later but they were in the mid-high 14's. like 2-2.1 60' times :/
I absolutely do not have my launch or shifting technique mastered, but I was still very surprised to be spinning like that.
It was at the Bradenton track in Florida if anyones familiar. There were 2 other evo's there that day and a couple STi's and nobody else really seemed to have an issue.
On the second pass I had the car at 5600 RPM (boost gauge bouncing between 5-8 psi) pulled my foot straight off the clutch quickly and I thought my clutch slipped because of the way the RPM's went, so I probably did take my foot off the gas a little too much. It wasn't until I talked to some friends afterwards that they told me I was spinning the front wheels.
Can't wait to get back out there and try again.
Old Jan 8, 2007 | 09:52 AM
ultimatesteve's Avatar
What is your trap speed? I didnt launch my car AT ALL and pulled a 14.3@103.60 and i have lees power then you.
Old Jan 16, 2007 | 08:18 AM
Bom's Evo's Avatar
I also spun in my lsd-ed 03'
almost all of 1st. and with a nice 1-2 shift, i could muster 89mph 1/8ths
PalmTreeZ
May 21, 2017 12:43 PM
evodude32
Jul 28, 2011 12:19 PM
neonglh
Aug 18, 2009 08:59 PM
Lucas English
May 5, 2008 11:57 PM
EvoDan2004
Apr 5, 2007 05:47 PM
